VLC 3.0 works with HFR
Discussion about 120fps HFR as well as future Ultra HFR (240fps, 480fps and 1000fps) playing back in real time on high refresh rate displays. See Ultra HFR HOWTO for bleeding edge experimentation.
Post by Chief Blur Buster » 11 Feb 2018, 23:14
Hello,
Just wanted to confirm the brand new VLC 3.0 does indeed work with HFR video files (120fps tested so far).
Cheers,
lexlazootin
Re: VLC 3.0 works with HFR
Post by lexlazootin » 12 Feb 2018, 11:10
120fps works for me, although it still don't work with G-Sync fullscreen :x ill probably test with 240fps for fun tomorrow
Post by RealNC » 12 Feb 2018, 11:55
Try different back-ends. OpenGL should work with G-Sync. However, whether it's useful or not depends on whether you can disable the triple-buffer-like behavior that many video players use (draw the same frame repeatedly.) In mpv this is called "display sync". VLC could be using something similar.
(This is used to minimize frame skips due to missing a vblank.)
Post by Chief Blur Buster » 12 Feb 2018, 12:11
Video players definitely do need to be VRR compatible to allow it to play any framerates.
Indeed, there's no such thing as a "missed vblank" when running with variable refresh rate -- the display simply waits for your software's frame instead.
nuninho1980
Post by nuninho1980 » 12 Feb 2018, 17:40
I tested new "Direct3D11" using VLC 3.0 final but... I got not always 50fps (= stutters randomly) at 50Hz. FAIL! :S I got no any stutters at Direct3D using VLC v1.1.9 and v2.2.6.
RAM: 2x16GB DDR4@3600MHz
MB: MSI PRO Z690-A DDR4
GPU: Zotac RTX 4090 non-OC <3 :D
HDD: SATA 1TB
PSU: AEROCOOL 1kW 80+ Gold
Disly: ACER Predator XB273U F5 !NEW! :mrgreen:
Post by Chief Blur Buster » 12 Feb 2018, 18:03
Hmmm!
You (we) should report this bug.
Post by Chief Blur Buster » 15 Dec 2019, 14:47
nuninho1980 wrote: ↑
12 Feb 2018, 17:40
Has this bug been fixed for 50 Hz? And other odd refresh rates?
nuninho1980
Post by nuninho1980 » 19 Dec 2019, 16:24
15 Dec 2019, 14:47
My new BenQ monitor doesn't cause bug but yes VLC on my old CRT monitor in the past year. I'll try newer version VLC at DirectX 11 to check if I get or not stutter (this is not equal to crosstalk).
--> LAST EDIT: On new v3.0.8, DirectX 11 doesn't work 50 fips (fields per second or frames interlaced per second) at "linear" or "bob" (deinterlace mode) and I tried to change to DirectX 9, OpenGL but these do not work yet but on v3.0.0, DX9 and OGL work 50 fips.
HDD: SATA 1TB
Post by Chief Blur Buster » 24 Dec 2019, 17:09
19 Dec 2019, 16:24
15 Dec 2019, 14:47
I wonder if this is a Microsoft issue or a VLC issue?
nuninho1980
Post by nuninho1980 » 25 Dec 2019, 14:05
24 Dec 2019, 17:09
I think Microsoft issue - Windows 10 v1903. :)
Test - DX9 with deintrelace enabled and deinterlace mode "X":
- Win 7 SP1 - VLC 3.0.7 works 50 fips
- Win 10 v1903 - VLC same version doesn't work 50 fips
HDD: SATA 1TB
