Strobe Utility 2.0 BETA Download!
Posted: 17 Feb 2018, 13:53
Strobe Utility 2.0 Beta Released
March 8, 2018
Its purpose is to improve the quality of Display Motion Blur Reduction on BenQ/Zowie monitors.
Supports most 144Hz+ BenQ/Zowie gaming monitors
>>> Download Strobe Utility 2.0.9 Beta <<<
(Use these links for sharing: permalink, or retweet this twitter, or share this Facebook)
-- Much better automatic detection of monitors
-- Much better multimonitor support (but must adjust 1 monitor at a time)
-- All strobe-capable BenQ/Zowie monitors supported.
-- Numbers match Factory Menu
-- Full Factory Menu range adjustment
-- Automatic rollback upon hitting Esc key (for old buggy monitors that black out -- e.g. old firmwares + large VT + large phases)
-- Optional Text editable BlurBustersStrobeUtility.ini file for advanced users (custom DDC command codes).
-- NEW: 2.0.9 has built-in TestUFO! No browser needed.
NOTE1: Bonus for advanced users: Includes text-editable master strobe command file that allows you to add future strobed monitors without waiting for a new software release. Also can be used to force strobe commands to "Generic PnP" monitors that don't show up in the pulldown list.
NOTE2: Click "Run anyway" if Windows prompts a protection message -- this normally happens with very small indie publishers like me, when a new executable file is run for the very first time that Microsoft doesn't yet recognize. I digitally signed the certificate using my own Rejhon Technologies. This MSI file and executable are digitally signed by me (Rejhon Technologies). This executable has been scanned to be 100% malware free.
Post bug reports here. If you prefer, you can email bug reports to [email protected]
March 8, 2018
