acer kg271b is worth $ 330 to buy? The cheapest 27 240hz
Astrolol
Post by Astrolol » 08 Mar 2018, 03:39
amd freesync, 240hz, 27-inch, input delay is my greatest concern, this would be the right choice?
k2viper
Re: acer kg271b is worth $ 330 to buy? The cheapest 27 240hz
Post by k2viper » 08 Mar 2018, 05:57
Other cheaper Acer 240hz 27" - XF270HA - has bad frameskipping.
You can try, but be ready that this can also have a major flaw.
viewtopic.php?f=2&t=3926
a26905092
Post by a26905092 » 19 Mar 2018, 16:08
It have HDR on HDMI(cap at 120hz)
And have blur reduction (call as MPRT at OSD)
You can turn it on in 240hz
But you can not turn on HDR and MPRT at same time
Post by Chief Blur Buster » 19 Mar 2018, 16:21
I've never heard of the KG271B. Which country?
a26905092
Post by a26905092 » 20 Mar 2018, 02:50
It sale in asian (china taiwan singapore japan)
It call KG 1 series
ACER KG251Q F 25" TN 1920x1080 144 1ms 400
ACER KG251Q D 25" TN 1920x1080 240 1ms 400
ACER KG271 C 27" TN 1920x1080 144 1ms 400
ACER KG271 B 27" TN 1920x1080 240 1ms 400
ACER KG271U A 27" TN 2560x1440 144 1ms 350
k2viper
Post by k2viper » 20 Mar 2018, 05:24
KG271B also sells in Russla.
a26905092 wrote:And have blur reduction (call as MPRT at OSD)
Can you provide pictures of OSD (MPRT) and provide pictures of http://testufo.com/crosstalk at 120, 144, 240hz with MPRT enabled?
There's no such option stated on Acer's site for this model. Also there's no downloadable user manual. It may be undocumented feature, but since that monitor is affordable one, its interesting to do these tests.
Also can you check it for frameskipping at 240hz http://testufo.com/frameskipping , because other Acer XF270HA has confirmed frameskipping at 240hz (and it is a major problem).
a26905092
Post by a26905092 » 20 Mar 2018, 14:30
k2viper wrote:KG271B also sells in Russla.
I don't own the monitors ,But I recommend to a lot people in Taiwanese forum
according to their report the MPRT did turn the monitor darker and make the UFO eyes clear
You can see that MPRT on OSD on this website GIF
http://www.coolpc.com.tw/phpBB2/viewtopic.php?p=642570
The price is really low 144hz TN (kg271B 320$ kg271C 255$) and have MPRT with OD also have crosshair
But I got a report is about Kg271C have Inductive sound on power button
https://www.youtube.com/watch?v=psbWK93-U_A
https://www.youtube.com/watch?v=I8YWe4V-xhs
And KG251 QAbmidpx (selling in japen) have bad input lag (1~2 fps slower than 60hz monitor)
https://www.youtube.com/watch?v=0fTa-dLLO4k
Also I have tools to measure input lag and color volume with color gamut coverage
But the manufacturer(only MSI and Acer replay me) say I'm a "user" no such "service" for me ):
k2viper
Post by k2viper » 21 Mar 2018, 04:50
There are two gifs with OSD settings.
Setting named MPRT is seen only for 144hz model (with buttons on front side)
240hz model have back side buttons and there's no MPRT option shown.
http://home.coolpc.com.tw/aes/open/acer ... 271-29.gif
http://home.coolpc.com.tw/aes/open/acer ... 271-30.gif
Is MPRT really in 240hz model?
a26905092
Post by a26905092 » 21 Mar 2018, 09:39
k2viper wrote:There are two gifs with OSD settings.
It seen like they are lazy and put less photo in the GIF
As user report , YES.
davidoo
Post by davidoo » 15 Jul 2019, 13:59
No info about this monitor yet? currently the cheapest 240hz monitor, where i live. And on top of that, its a 27".
