G-Sync Woes - Green artifacts and stuttering video
ultima786
Post by ultima786 » 16 Mar 2018, 16:49
Hi all,
Really struggling here with two issues playing Final Fantasy XV.
1. Using drivers 390.01 or 390.05, I get weird-green artifacts in the lighter parts of the screen when using g-sync. It only happens when g-sync is on. See these pictures (They aren't FFXV, nor are they mine, but they are the exact same issue).
If i roll back all the way back to driver 388.71 the problem goes away. Any tips?
2. No matter what driver I use, I get weird, stuttery playback from full-motion video cutscenes (not in-game cutscenes). It's almost as if the the video isnt playing at the right FPS. If I turn off g-sync, the problem goes away or improves dramatically. SOmeone told me it's because I was using an external FPS limited. However, I tried both Special K Mod to limit FPS, and I tried the internal FPS limit, and no limits at all, and the probelm seemed to persist (but of course, if I used no limit, then g-sync wouldn't really work because it would be playing faster than my monitor refresh rate of 60 hz).
Really struggling here, would appreciate guidance!
Specs: Powerspec 1510, g-sync laptop monitor, gtx-1070, i7-7700hq
Re: G-Sync Woes - Green artifacts and stuttering video
Post by Chief Blur Buster » 16 Mar 2018, 19:10
Hmmm... 388.71 fixes it?
Yeah, it's probably a driver bug.
