Does anyone know what the input lag of the Viewsonic XG2560 has? I'd like to buy the fastest monitor for gaming, 240hz, 1ms gtg, and the least amount of response time black to white, as well as the lowest amount of input lag, 10ms or less would be nice, does anyone know which monitor that would be? I don't think I'll use g-sync since I know v-sync adds lag and I'm assuming g-sync would do the same but make it smoother when my fps drops below my refresh rate.
Thanks! Chief Blur Buster, would you be able to answer this?
Input lag of Viewsonic XG2560 and/or lowest of a 240hz lcd
Speedfreak
Re: Input lag of Viewsonic XG2560 and/or lowest of a 240hz l
Unfortunately only a few sites like tftcentral and prad.de regularly do latency tests when they review a monitor, and a quick search didn't turn up a measurement of that monitor.
All 240hz must be ok with this parameter. If you wanna be sure then buy some BenQ for example BenQ XL2540 or Asus.
