OCD question gsync monitor with amd card
Posted: 08 May 2018, 09:51
by reqq
Hi if i use a gsync monitor with an amd card will that bypass the gsync module or will the signal go through it? Just wondering if it possible for nvidia to code a disadvantage monitor behavior if the module detects an amd card
Just bought a gsync monitor but will use it for the time being with my amd card.
lol
thanks.
Re: OCD question gsync monitor with amd card
Posted: 08 May 2018, 09:56
by RealNC
It will use the g-sync module, since it's not just there for g-sync, but it replaces the monitor scaler completely. There are no ill effects.
Other benefits of the g-sync module still apply, regardless of the GPU you use (like NVidia's very good overdrive implementation.) Not sure if ULMB (motion blur reduction) will still work on AMD though.
Posted: 08 May 2018, 17:44
ULMB does not work with AMD.
It needs to detect an NVIDIA card to unlock GSYNC and ULMB features. Without it, it just behaves as an ordinary fixed-Hz 240Hz monitor.
The good overdrive will still apply but you won't derive variable refresh rate or blur reduction benefits.
There is no lag disadvantage -- fixed-Hz does not get increased lag compared to other fixed-Hz monitors and you will often get lower lag than from more generic 240Hz monitors. A bonus is you won't get frameskipping like those found in some buggy 240Hz monitors (e.g. the early AOC 240Hz non-GSYNC monitor or the early ACER 240Hz non-GSYNC monitor). So the NVIDIA testing does debug your monitor well, even if you don't gain the GSYNC/ULMB feature. To be fair to AMD, I can say AMD FreeSync2 testing does a good job too. So you've already gained some maturity advantages over some early 240Hz monitors from almost two years ago.
Posted: 09 May 2018, 08:52
by reqq
thanks
