Monitor Recommendations
The XBOX ONE Console supports 120Hz+, FreeSync, and 1440p. Getting help with getting "Better Than 60Hz" on the XBOX ONE.
TheTechGuy
Re: Monitor Recommendations
Post by TheTechGuy » 09 Jul 2018, 06:35
richdot wrote:I would highly recommend the Asus VG245 on my experience.
I've got is as well and its great although I have experienced some problems recently.
TTT
Post by TTT » 15 Sep 2018, 10:23
Chief Blur Buster wrote:If you don't care about a few milliseconds more lag (extremely minor VA lag instead of near-lagless TN) then I'm feeling pretty good about the Samsung CHG70 series for desktop XBox One use. Even if laggier than TN panels (poorer colors), the new Samsung quantum dot FreeSync monitors have less lag than HDTVs.
-- Some of the best colors I've seen in a gaming monitor under $1000
-- HDR with quantum dot backlight
-- Excellent 120Hz blur reduction mode (if game is running 120fps)
-- FreeSync support
-- One of the only monitor manufacturers to provide user-firmware upgradeable desktop monitors!
Samsung C27HG70 - 27" 2560x1440 VA 144Hz FreeSync
Samsung C32HG70 - 32" 2560x1440 VA 144Hz FreeSync
If you're concerned about high quality and futureproofing for quite a while, these are pretty comfortable choices.
Now, if you're a console competitive/eSports player, and need TN instead of VA quality -- then you may have a preference towards a TN panel...and that does get to be a little bit of a tougher choice because of a huge array of options depending on your priorities.
I tried the 24" version of this with my Xbox One a while ago and it had massive input lag.
Post by Chief Blur Buster » 21 Sep 2018, 20:11
There's no 24 inch version of the improved CHG monitor -- which model 24" monitor was this?
       To support Blur Busters:
       • List of G-SYNC Monitors
       • List of FreeSync Monitors
       • List of Ultrawide Monitors
TTT
Post by TTT » 29 Oct 2018, 13:31
Chief Blur Buster wrote:There's no 24 inch version of the improved CHG monitor -- which model 24" monitor was this?
Just realised these are the 1440p monitors.
It was the C24FG73, basically the same as the ones above but 1080p.
Post by Chief Blur Buster » 30 Oct 2018, 15:04
Oh! The CFG series. Yes, that's the one.
If you get that, the -73 is definitely the newer/better version than the -70 of which early versions were known for their purple ghosting haze problem.
TTT
Post by TTT » 30 Oct 2018, 15:13
Chief Blur Buster wrote:Oh! The CFG series. Yes, that's the one.
Yes I remember reading that was the updated version that fixed some kind of purple ghosting. The monitor looked awesome and the picture was brilliant but its the most input lag I've ever felt on my Xbox. I went from an RL2455 to that but also have an older 32" Sony Bravia which is pretty bad, but the Sammy was way worse.
