Getting back in the groove with G-Sync & Emulation
BlackGuyRX
Post by BlackGuyRX » 05 Jun 2018, 01:27
Alright, it's been a while since I've tried to really mess with G-sync and RA so i'm gonna try again and I need help from anyone who can offer assistance. I've got a AOC G2460PG 144hz G-Sync monitor and running Win10. RetroArch is my emulation platform of choice but i've never been able to get it completely get along with G-Sync. Even when I think i've figured it out, there's still some minor audio stutter or scrolling isn't smooth and slight judder creeps in. I've come across jerry-rigged settings from different users but no real 100% fix-all so far.
I'm trying to figure out how I can run RA and actually have it properly utilize G-Sync, assuming it even can....
I just want buttery-smooth scrolling without stuttering sound or whatever else might happen and I'm at my wit's end.
lossofmercy
Re: Getting back in the groove with G-Sync & Emulation
Post by lossofmercy » 08 Jun 2018, 09:08
I am with you, we need a standardized config for gsync that people can lookup easily. This is definitely on my list once I get better.
My goal is to get ULMB working with retroarch too.
Post by Chief Blur Buster » 11 Jun 2018, 23:15
With ULMB -- make sure you use the ULMB 60 Hz hack.
With GSYNC, I got some info that these RetroArch settings help a lot:
GSYNC turned on in NVIDIA Control Panel
Audio Sync: On
audio_rate_control = "false"
Vsync in RetroArch: Off
Vsync in Nvidia Control Panel: On
Maximum runspeed: 1
Windows Power Plan: Performance
If you get any improved RetroArch settings, post them here. Thanks!
Post by Chief Blur Buster » 11 Jun 2018, 23:18
More settings:
wenarlin wrote:im using retroarch, and it is going fine
You need to "audio sync on" - this is the main, and the only stable framethrottling method
You also need to run "high perfomance" profile in windows power options
You need to configure you audio interface like this Image - this need for audio sync - to work properly
Finally here is my RA config file:
http://puu.sh/zuhJi/64f2fd81d9.zip
just edit it, and enter correct refresh rate for you monitor (my is 165hz)
again: The main options for G-sync setup is:
audio sync=on
v-sync=off
hard GPU sync=on
hard GPU sync frames=0
max swapchain images=1 (this is for minimum input lag)
threated video: off (this is for minimum input lag)
Do not use "frame throttle" - it is cause huge stutter !
Sorry for my english - im from Russla :D
good luck! retroarch with g-sync - it is a real mind blowing expirience - this is like gaming on real console with CRT TV
BlackGuyRX
Post by BlackGuyRX » 18 Jun 2018, 00:44
Chief Blur Buster wrote:More settings:
audio sync=on
v-sync=off
hard GPU sync=on
Hey there, sorry for not replying earlier. Tried all these and so far, I still appear to see some minor stutter....
When I get the chance, i'm gonna go over these steps, probably more thoroughly than before to see if I get different results.
