need help to purchase a monitor for ps4
Posted: 22 Jun 2018, 20:28
by ahmedpc03
Hi
i would like to buy a monitor for my ps4
and i prefer to get an ips monitor and one of these lg monitors
27MP59G
32MA68HY
27MP59G is a gaming monitor and guaranteed with low input lag
but i dont have an idea if the 32MA68HY have low input lag or not
i prefer to get a bigger monitor, both of them have 5ms response time
also the philips 323E7QDAB is 5ms but i dont have an idea if is it also have a low input lag or not
the philips one is available in a local shop which is good for me
please need help guys to choose a monitor with low input lag
thanks
Re: need help to purchase a monitor for ps4
Posted: 23 Jun 2018, 01:32
by RealNC
If Sony ever decides to support freesync, the 27MP59G is the better pick. If they'll never add that, and you prefer larger screen size, then the 32MA68HY is probably the better pick for you. Note of course that since we're talking about 1080p screens here, the larger the screen is, the worse the image quality gets.
The blur reduction mode of the 27MP59G is probably limited to 75Hz so it's not useful for a PS4. I might be wrong, but I doubt LG would support 60Hz blur reduction mode.
Other than that, none of these monitors have detailed reviews available. So we don't know what their input lag is. We know as much as you do. However, since these are monitors and not TVs, they will have much lower input lag compared to a TV.
Posted: 23 Jun 2018, 04:43
by ahmedpc03
thanks for your reply
according to the displayspecifications.com
https://www.displayspecifications.com/en/model/c376b22
the lg 27mp59g
have 11ms input lag, which is very good
do you think bigger monitor have more input lag or its not necessary!
Posted: 23 Jun 2018, 04:54
by RealNC
ahmedpc03 wrote:do you think bigger monitor have more input lag or its not necessary!
I don't know. I can't find any tests.
Posted: 23 Jun 2018, 06:03
by ahmedpc03
alright thanks
Posted: 09 Jul 2018, 05:09
by JoshPeterson654
I would go with the first option if I were you.
Posted: 10 Jul 2018, 00:41
by haanuman
Same, I would go with 27MP59G most probably as well! Let us know which one you get and how it goes with the new monitor
Posted: 10 Jul 2018, 08:11
by ahmedpc03
haanuman wrote:Same, I would go with 27MP59G most probably as well! Let us know which one you get and how it goes with the new monitor
my nephew got this monitor and playing fortnite alot, hes very happy with it, clear motion comparing with his old tv and no noticeable input lag at all
usualy lg ips monitors offering better colors comparing with the others. but with little higher response time 5ms
i can see only acer offering 60hz ips monitors 1080p with 4ms response time, but i dont have an idea if there well be a noticeable different between 4ms and 5ms on 60hz
