Hello there,
i'm looking for some guidance.
After some reading i can't decide between
XL2420Z and BenQ XL2420T rev2.0
I use the pc up to 10hrs per day, browsing, reading and some games.
I'm looking for something that will be sooo easy on my eyes, my Samsung t260 just keeps killing me...
Thank you very much for your time
Seeking for advice
whilson
Re: Seeking for advice
i love my xl2411z , and i dont think a little switch is worth more money
take the xl2411z:P
waterboy849
I would get the benq 2420z especially if you read and browse a lot because of the new low blue light feature.
It's great to have both PWM-free ZeroFlicker (for mainstream use) and motion blur reduction strobing (for FPS gaming use) as options in the same monitor, and both monitors support these capabilities, via different methods (XL2720T uses LightBoost, and XL2720Z uses BENQ Blur Reduction)
NOTE: In regards to the purchase of the Z-Series, if you are considering compatibility with Blur Busters Strobe Utility very important, then wait for the upcoming forthcoming news if you are wanting to verify compatibility with the Utility before purchasing your Z-Series, if plans to use motion blur reduction factors into your plans.
