DP 1.2 VS HDMI 2.0
srsbsns
DP 1.2 VS HDMI 2.0
Post by srsbsns » 30 Jul 2018, 21:12
Is there any technical differences that you would prefer using one over the other when it comes to DP and HDMI on FreeSync?
fenderjaguar
Re: DP 1.2 VS HDMI 2.0
Post by fenderjaguar » 26 Sep 2018, 05:37
As far as I see, there's no difference
Post by RealNC » 26 Sep 2018, 09:49
They work a bit differently, but the end result is identical. With that being said, I prefer DP, because it was made for computer monitors while HDMI was made for TVs :P
