Hello i bought this display yesterday , and i dont understand why i have problem with UFO test in google chrome. Ufo test write me, stuttering problem, or majority stutter problem, on the old display no problems just on the new... New is 144hz , g-sync . I have I7 6700k and Gtx 1080 Ti . Its problem of my new monitor its possible ? or its problem chrome ? can somebody help me?
Big thanks
LG 32GK850B Ufo test problem
- RealNC
Re: LG 32GK850B Ufo test problem
It's not a problem with the monitor. This is because something on your PC is causing CPU load, which results in stutters in UFO.
Zofrenko
if i looking task manager, cpu usage is max 1-3 percnet, and i think i7 6700k its not low Cpu . I dont know how to fix it
RealNC wrote:It's not a problem with the monitor. This is because something on your PC is causing CPU load, which results in stutters in UFO.
On Windows, for default untweaked unbugged installs of Chrome, TestUFO is stutterfree on GeForce/Radeon cards at these CPU utilizations.Zofrenko wrote:if i looking task manager, cpu usage is max 1-3 percnet, and i think i7 6700k its not low Cpu . I dont know how to fix it
If you are getting a red stutter message instead of a green "READY" message -- then go to http://www.testufo.com/browser.html and try debugging -- e.g. enable/disable hardware acceleration. Sometimes the Chrome flags are misconfigured, testing a different browser, disabling multimonitor, etc.
