If you're interested in scaling the image on your PC and sending it out at max refresh there is another option as well:
http://www.softth.net/. It's kind of like a software Eyefinity and it requires injection for DirectX programs, much like InjectSMAA or SweetFX do. However, it is not 100% compatible with everything, so read up on it first. You can use SoftTH with other injectors as well, like InjectSMAA, but there are some hoops you'll need to put your jumping shoes on for as they require different .dll files but have the same name so you'll have to rename one and then edit and re-direct the other .dll to the first .dll to get them to work together. Of course you could use RadeonPro for SMAA/FXAA/shader injection as well which in general is just much easier. But either way, there are options for everything and SoftTH is one of them.
If your preference is Image Quality before Refresh Rate though, you should try using actual resolution timings with some downsample resolutions to see what you prefer. In many cases a display can scale the image better than the GPU. On the Vizio M651d (1080p) I prefer playing 2560x1440 at 82hz with actual 1440p timings rather than with NVIDIA CP custom resolution of 2560x1440 "desktop" with 1080p timings at 103hz, unless its a competitive (snap reflex) FPS game. It scales much better on the panel with the actual 2560x1440 timing, even if it is only 81-82hz. On the other hand, 3840x2160 "desktop" with 1080p timings at 48hz is (by far) my preference over actual 4K timings at 37hz. 11hz doesn't seem like it would make a big difference in lag, but at refresh rates that low there is an easily noticeable difference between the two. With 3200x1800 its literally about a 50/50 split depending on the game and how much input lag comes into play. With something like Tomb Raider I'd play at 52hz with actual 3200x1800 timings, but Deus Ex: Human Revolution I'd play at 78hz with 1080p timings. On the Samsung UN55C7000 3600x2025 "desktop" at 60hz with 1080p timings were pretty sweet considering that panel wouldn't overclock to even 61hz without blurring like a Sims character taking a shower. The options on that panel were 1080p at 60hz or 3600x2025/1080p timings at 60hz so it was a pretty simple decision to choose your resolution on that one. Except for 3D Vision games, 1080p at 60hz Checkerboard with active 3D glasses was pretty epic...
As far as AA goes, Downsampling is typically the heaviest option to go with, which is why some are opposed to it. However there is a whole other side of the argument that many do not take into consideration and that is the difference in texture quality between a game being rendered in a higher resolution vs using an edge detect method of AA at a lower resolution. If you don't believe it, try this: Render a game capable of running a ridiculously high level of AA like 32x CSAA at 720p with the AA maxed out. Then turn the AA off in the same game and render it at 5120x2880 (16 x 720p, 4 x 1440p). If you liked that, try the same thing with an SMAA injector or FXAA with a mandatory LumaSharpen shader (then add an HDR shader and tweak RGB gamma settings and succumb to that which is SweetFX
). My point though is that AA isn't the only thing to consider when it comes to downsampling.
Of course the above example is more relevant with current/recent games than it is with older games. For instance there is a beneficial AA effect when using 3200x1800 in Star Wars: Republic Commando vs 1080p, but the texture quality argument is null in this instance. Even with the game's Ultra High textures there is no real difference as it was made to max out at 1600x1024 (if I recall correctly) and it has pretty low quality textures regardless of what the engine refers to them as (but in its defense it is pretty much the greatest Star Wars game ever made! ...well since Star Wars: TIE Fighter Collector's CD anyway).
