Hello
I have a problem with my monitor Benq XL2735 (see attached photo): the colors of the leaves are not aligned.
What is it?
thank you
Artifacts Benq XL2735
diodema
- Screenshot_2018-11-05-16-20-20-921_com.google.android.apps.photos-270x418.png (253.61 KiB) Viewed 5126 times
- copia ridotta.png (240.24 KiB) Viewed 5139 times
- RealNC
Re: Artifacts Benq XL2735
Does it also show if you take a screenshot?
- RealNC
Then it's not the monitor. It's the game. What game is it? It looks like an extremely overblown chromatic aberration effect (I hate that effect myself and always disable it if it's an option, or a tweak in the game's ini files.)diodema wrote:Yes
diodema
You are my hero: It's the game.RealNC wrote:Then it's not the monitor. It's the game. What game is it? It looks like an extremely overblown chromatic aberration effect (I hate that effect myself and always disable it if it's an option, or a tweak in the game's ini files.)diodema wrote:Yes
Thank you so much
Yes, these are GPU effects. You may need to surf through the game menus and turn off "Chromatic Aberration" or "Lens Flare" or "Lens Effects" or any similar sounding option.
Falkentyne
Sorry to bother you, Chief, but please check your PM if you have time.Chief Blur Buster wrote:Yes, these are GPU effects. You may need to surf through the game menus and turn off "Chromatic Aberration" or "Lens Flare" or "Lens Effects" or any similar sounding option.
