G-sync / xbx one x 120hz
All newer XBOX consoles supports 120Hz+ & FreeSync. Getting help with getting "Better Than 60Hz" on the XBOX ONE, XBOX Series S, and XBOX Series X, as well as the PlayStation 5.
Lak
Post by Lak » 18 Dec 2018, 10:54
I was just wondering if i can get at lease 120hz over 1080p on a g-sync monitor with my xbx one x since i want to get a new monitor that will also work for my gaming pc rig (gtx1070ti) Thanks !
Re: G-sync / xbx one x 120hz
Post by RealNC » 18 Dec 2018, 11:14
I don't think g-sync monitors support more than 60Hz when using an HDMI cable. They need DisplayPort.
Maybe an HDMI to DisplayPort adapter will help, but I'm not sure.
