FRC - temporal dithering
tomsx
I considering 'upgrading' my AOC Q2577PWQ to Q3279VWFD8, the latter is superior in several aspects
it has FRC (8+2) though
the question is if I send 8 bit signal to it, will FRC stay off/unused ?
- RealNC
Re: FRC
Why wouldn't you want FRC?
- RealNC
Re: FRC
The effect of dithering is that it improves image quality. Why wouldn't you want that?Kheri wrote:Don't like the effect of dithering, I imagine?
Kheri
Re: FRC
Supposedly noticeable (especially in peripheral vision) in the past with 6bit+FRC. Dunno how much better the dithering algorithms are now (heard they're much better) or how noticeable that'd be with 8bits+FRC.RealNC wrote:The effect of dithering is that it improves image quality. Why wouldn't you want that?Kheri wrote:Don't like the effect of dithering, I imagine?
Re: FRC
6bits look a lot worse than 6bit+FRC.
Likewise, 8bit+FRC should generally look better. There may be an issue when you do things like software black frame insertion, which may temporally interfere with FRC sequence.
tomsx
Re: FRC
well, thx everyone... ye, I'd rather avoid flickering, even if it's subtle...
anyway, on my way to return it... that IPS glow, seriously... feels like every colour is bright, no matter what setting, lacking some depth... plus 2 dead pixels, cherry on top of the cake :V
Falkentyne
Re: FRC
6 bits looks more than just a lot worse than 6 bits+FRC.Chief Blur Buster wrote:6bits look a lot worse than 6bit+FRC.
It looks absolutely terrible.
The Benq XL2720Z is a 6 bit +Hi FRC (i dont know the difference between FRC and hi-FRC) panel, which is supposed to simulate 8 bit depth by supporting it.
It does work good (i'm sure there are some artifacts in the far gray scales), but if you exceed 359.90 mhz pixel clock, it switches to pure 6 bit (the drives switch from 8 bit to 6 bit).
The banding in Overwatch is....terrible.
I mean it's barely better than playing in 16 bit desktop color depth.
BTW Chief, on the XL2720Z, with normal 8 bit (6 bit+Hi-FRC), on some web browser gray tones or light cyan/gray tones, you can actually see the dithering going on if you look close enough.
Re: FRC
Even I, personally, fell it is useless to worry about flicker on 8bit+FRCtomsx wrote:well, thx everyone... ye, I'd rather avoid flickering, even if it's subtle...
Even all incandescent lightbulbs have a bigger flicker curve than 8bit+FRC! People who can't see flicker in incandescent lightbulbs, won't see the flicker in 8bit+FRC. The flicker is coming from something else such as imperfect backlight or from inversion artifact (not FRC).
8bit+FRC is a 0.4% change that occurs so rapidly that it's hidden by the GtG.
It's not the full-on-off flickering of DLP/plasma pixels.
Inversion artifacts are much more noticeable.
Now....6bit+FRC, we're talking. That's big enough of a flicker ratio.
