colour banding,
dippadui
colour banding,
Post by dippadui » 31 Mar 2014, 22:33
is there any way to reduce colour banding? (xl2411z) video gard is gtx 660, i use settings providet from ---> http://pcmonitors.info/reviews/benq-xl2420z
it have the same panel than 11z. i use 144hz icc...yes i know every panel is unique.
thanks.
spacediver
Re: colour banding,
Post by spacediver » 31 Mar 2014, 23:08
do you see banding without using the icc file?
dippadui
Re: colour banding,
Post by dippadui » 01 Apr 2014, 08:22
yes almost same i have tested different icc profiles.
dippadui
Re: colour banding,
Post by dippadui » 01 Apr 2014, 10:33
these are bf4
bf4 2 (800x452).jpg (103.17 KiB) Viewed 7465 times
spacediver
Re: colour banding,
Post by spacediver » 01 Apr 2014, 12:40
posting screenshots won't help. If the banding is an issue with your display or your video settings, it will only show up on your display. How severe is the banding?
dippadui
Re: colour banding,
Post by dippadui » 01 Apr 2014, 13:34
spacediver wrote:posting screenshots won't help. If the banding is an issue with your display or your video settings, it will only show up on your display. How severe is the banding?
well,its there but not very much, just thinking can it be fixed or reduced.
masterotaku
Re: colour banding,
Post by masterotaku » 01 Apr 2014, 14:02
I have the same monitor as you. Banding is normal in this type of panels, as they are 6bit + FRC (dithering). Another issue could be in the game itself. The sky is something prone to banding in games, and some compressed textures can have it, or even the lighting system itself (I think).
There's nothing you can do about the monitor (provided that your gamma and contrast are OK). If the monitor says "I'll represent this shade of color by dithering", nothing can be done.
Monitor: Asus PG278QR
dippadui
Re: colour banding,
Post by dippadui » 01 Apr 2014, 14:17
ok thats fair enouch,thanks ;)
