Strobe Utility v2.0.9 crashes
Posted: 10 Mar 2019, 15:29
by syXzor
Strobe Utility v2.0.9 does not work for me.
It opens, and ufos start moving for 1 second, then it stops and I get 2 dialogs in the background:
1: Create vertex shader fail : DrawBasic.fx
I click ok and I get another dialog:
2: m_fnInitialize Fail
I click ok and the program exits.
Details:
Benq XL2720Z, firmware v5
Asus RTX 2080 Rog Strix
Nvidia driver: 419.35 (release 2019.3.5)
Ryzen 2700X
Asus X-470 Prime Pro
Windows 10 Pro
1080p@144Hz
Re: Strobe Utility v2.0.9 crashes
Posted: 20 Mar 2019, 10:50
Hmmmm. This might be an RTX-series specific bug relating to the graphics framework I use for the UFO animations.
Try launching again and immediately pressing spacebar to turn off the motion test as quickly as possible.
(Spacebar turns on/off the motion test built into Strobe Utility)
Does that bypass the error messages?
I've got a full plate in the near term but in April/May, would you be willing to help me debug Strobe Utility with the RTX series?
Email me [email protected]
