I'm looking to get a freesync monitor as I don't want to be locked into Nvidia cards for the next 5 years or so (my current monitor has lasted 10 years). I mostly want good gaming performance with minimal ghosting with decent colour accuracy and contrast as secondary priorities.
I play AAA FPS games like Battlefield and while I've got a good GPU now (RTX 2080), I won't be upgrading that every couple of years so I need a monitor that looks good down to ~50 FPS.
To that end ideally I'd want a freesync monitor with adaptive overdrive. The Nixeus EDG 27 has been touted as having adaptive overdrive but I can't find any actual measurements of this capability either in the form of the UFO test or response time values at varying refresh rates. The only review with a UFO test I've found doesn't seem to have done the UFO test correctly based on the broken ladder https://www.custompcreview.com/reviews/ ... erformance. Can anyone who's had experience with the monitor help me out? Will it meet my requirements?
As an alternative I'm considering the AG27QX which I'm hoping as a TN monitor will have acceptable levels of ghosting even without variable overdrive. This of course also means sacrificing some of the other benefits of the IPS monitor but it's a lot cheaper where I live.
Also if anyone can recommend any other 1440p 27" IPS Freesync monitors with good overdrive implementations that'd be cool too.
Nixeus EDG 27 Ghosting and Overdrive
Re: Nixeus EDG 27 Ghosting and Overdrive
Alas, you may want to trade-up your monitor a little more often than 10 years because the technology is changing a bit faster with gaming monitors.
You have an NVIDIA card, so an alternative is to get a native GSYNC monitor -- these do include dynamic variable overdrive in sync with their variable refresh rates. It's included as part of the "GSYNC premium".
VRR makes fluctuating framerates look pretty comfortable to look at, an erratic fluctuating framerate 40-60fps looks much more comfortable on a VRR display than a non-VRR display.
