until now I have been using dvi dual link on the monitor and gfx card, lightboost at 1080p/120 hz, and some games no lightboost 1080p/144 hz, works super good,
but my question is , is there any risk at all of lightboost not working good/correct with displayport connector? or it does not matter at all what connector is used as long as it supports 120hz/1080p resolution and enough pixelclock etc?
bonus question: if anyone has vg248qe and using displayport, are there any issues with black screen on boot/flickering/not being able to set 144hz refreshrate etc? or that only depends on bad displayport cables ?
according to vg248qe manual it supports up to 144hz 1080p on dvi and dp connector, but is old monitor from 2012 and is only dp 1.2 , so am still semi-worried before my purchase
Cheers and thanks for any help
