Dyac High vs. Premium
progamingnoob
What's the difference between dyac high and premium and how it affects the 182hz tweak.
progamingnoob
Re: Dyac High vs. Premium
Just making sure that you're talking about DyAc and not AMA?RealNC wrote:It controls the strength of the pixel overdrive. Lower values result in higher pixel response times and more ghosting. Higher values result in lower pixel response times and more reverse-ghosting. To find the best setting for your monitor, you can test the different settings while viewing this animation:
https://www.testufo.com/ghosting
Use the setting that gives you the clearest image. Which setting is best differs from display to display. On most displays the best setting is usually the middle one. But with BenQ/Zowie displays sometimes the higher settings are best. So test it yourself in the above URL.
- RealNC
Oops, you're right. I confused this with AMA.
Never mind
Never mind
evmadic
Figured I'd bump this since I haven't been able to find an answer.
Although I will say that 'High' as opposed to 'Premium' does feel like less input lag.
5800x3d, RTX 4070 ti, Acer Nitro XV252QF 390Hz
https://www.twitch.tv/evmadic
