yungracks wrote:I bought this gsync monitor a few weeks ago & i still stutter below my refreshrate.
Are you talking about erratic stutter or regular stutter?
GSYNC cannot fix regular stutter (low framerates such as 30fps will still look stuttery) but can really smooth erratic stutters, where 110fps-130fps fluctuating framerates look like a perfect 120fps, and such.
Can you identify what the stuttering looks like currently? Microstutter, random disk-freeze stutters, erratic stutter, etc. GSYNC fixes the visibility of most stutters but not all of them. That said, we should make sure that fixable stutters are indeed fixed by GSYNC. Before I can do so, I need to make sure what kind of stutters you're seeing.
Not Fixable by GSYNC
- Diskload stutters. (e.g. half-second freezes). Get an SSD to minimize this.
- Low framerate regular stutter. (e.g. stutter of 30 frames per second). Get more powerful GPU to get framerates higher.
- Game bugs that insert stutters not fixable by GYNX
Fixable by GSYNC
- Tearing
- Many forms of microstutter
- Framerate-change erratic stutters (the erratic stutter of a fluctuating framerate)
- Single-framedrop stutters (59fps@60Hz problems = disappear)
For example, a high-framerate erratic microstutter (e.g. 10 tiny vibrations per second) is fixable. GSYNC can erase the seams between adjacent framerates, so the change of 58fps -> 59fps -> 60fps -> 61fps -> 62fps .... is rendered completely invisible. Even random framerates (that are within a 10% framerate span) are visually seamless. There's no more framedrop-style stutters with GSYNC.
However, GSYNC will not fix those 100fps -> 0fps -> 100fps "game minifreeze" stutters. Nor GSYNC will fix those chop-chop-chop-chop regular (non-erratic) stutters of ultralow framerates like 10fps, 15fps, 20fps, 30fps, 35fps -- even if its within the bottom of the VRR range (or low frame rate compensation region). Yes, GSYNC will fix the erratic stutter (a framedrop style "jump") of 35fps->34fps->35fps but not the regular stutter of the respective framerates (either 35fps or 34fps looks choppy even if the framepacing is perfectly exact).
yungracks wrote:Is it bad that my screen is flickering in loading screens
Flickers can occur if there's major framerate fluctuation, which means a monitor can jump all the way from 240Hz all the way down to 30Hz, and then back up. This is challenging for a 30Hz image to always perfectly match a 240Hz image (e.g. pixel response curves, overdrive, color calibration, LCD inversion, etc), so the wild framerate fluctuation cause some visible image changes that means the refresh rate switching has a noticeable subtle flicker. Not a 2-second mode change flicker but a very faint flicker.
