Severe Crosstalk with new XL2546?
Posted: 06 Jun 2019, 17:09
Hi everyone,
I've read quite a bit on this site about blur reduction, crosstalk, etc.
After a lot of research, I bought a Benq Zowie XL2546 today.
I mainly play Overwatch and I wanted to get a monitor that would give me as little motion blur as possible while maintaining brightness.
I don't yet have the hardware to run OW in 240hz, so i set the refreshrate to 144hz.
To my surprise, there was a LOT of crosstalk after doing the UFO test, especially at the bottom and top. Considering I am running at 144hz, I was expecting a much clearer image - I've seen a lot of photos of this test on here and the results are usually far better, with higher refreshrates.
I've tried every setting I could think of and find - all combinations of High/Premium on Dyac/AMA, adjusting the Area (this only moved the extreme crosstalk from the top to the bottom of the image), the persistence, the OD Gain in the factory menu - nothing helped.
I've also created a custom resolution in toastys CRU program following the guide in the appendix. This did absolutely nothing to help with the crosstalk. I ended up at 2020VT total.
What could be the issue? Do I have a defective model?
Picture: https://imgur.com/a/AZFHdTf
vs
