Hi there,
Sweet website, really good articles and info.
Just a quick Q as I'm looking to purchase one of the 144hz Benq monitors.
With the 2411Z series can you turn off Blur Reduction if you don't want to use it? I couldn't find any information about this and I'd prefer to go for the 2411T if that were the case.
Thanks in advance,
T
RE: Benq Blur Reduction [How easy to turn on/off?]
Falkentyne
Re: RE: Benq Blur Reduction
Yes its a toggle option on the monitor.
Blur Reduction is easier to turn ON/OFF than LightBoost is.
It works on all graphics cards, and easily works on Mac/Linux, unlike LightBoost.
badbeatz
Re: RE: Benq Blur Reduction [How easy to turn on/off?]
Thanks chaps!
Got my £1000 rig sorted now ^^
