Just recieved 0.5ms AORUS KD25F
BlurBoss
I've just received AORUS KD25F and would be happy to answer your questions and get to know that monitor better in the process. I have been using BenQ XL2546 for 6 months and currently deciding if I should keep AORUS KD25F to replace it or return it. I have 7 days to decide.
First impressions:
-Can't enable G-Sync and Aim Stabilizer (AORUS' name for Blur Reduction) at the same time.
-Aim Stabilizer reduces brightness significantly, while BenQ XL2546 doesn't lose any brightness with Blur Reduction.
First impressions:
BenQ XL2546, i9-9900K @ 5.0 GHz, RTX 2080 Ti, 32GB (2 x 16GB) 3200 MHz CL14 RAM, Asrock Z390 Phantom Gaming-ITX/ac.
do0om
Re: Just recieved 0.5ms AORUS KD25F
Do you have a slow motion camera to compare input lag with benq?
Notty_PT
It is laggy and overdrive is really bad imo, but we all different. And Benq xl2546 is not an amazing model too, he might prefer the gigabyte one.
open
how does it feel in competitive games?
have you tried all the overdrive modes?
BlurBoss
I shot 240 FPS video (the highest I have access to), connected both monitor to different DP port in the video card and did Win+P - Duplicate. When going through the video frame by frame, there is no difference in input lag.do0om wrote:Do you have a slow motion camera to compare input lag with benq?
BlurBoss
The first 5 minutes I noticed that KD25F feels much more responsive than XL2456, I play Rainbow Six: Siege competitively (I don't participate in any championships, just for leisure). With it KD25F+Aim Stabilizer I can easily control revolver's recoil, something that was more difficult with XL2456+DyAc before. While shooting automatic riffles, I can see enemies clearly (first time ever muzzle flushes started to annoy me, I've never noticed them before), yet it doesn't affect my aim yet. The only bad thing about this monitor is that when I enable Aim Stabilizer, the screen loses brightness which results in worse picture quality than XL2456 - this might be a deal breaker for me. It's a shame, because KD25F looks so much better in every other aspect, but I'm only using it for gaming with Blur Reduction On, so this monitor might provide worse experience for me.open wrote:how does it feel in competitive games?
I wonder why XL2456 doesn't get darker with Blur Reduction On, while every other monitor does?
Voltage boosted backlight / edgelight.BlurBoss wrote:I wonder why XL2456 doesn't get darker with Blur Reduction On, while every other monitor does?
The backlight is overvoltaged during flashes, as LEDs can usually safely flash 3x-4x brighter than steady state.
More expensive electronics to engineer, and improper engineering can wear down the LEDs faster. But these produce ~300nits strobed on many 240Hz models, including 25 inch DyAc-branded (BenQ ZOWIE) and 25 inch ULMB-branded 144Hz (240Hz real-NVIDIA) modes are usually brighter than most competition.
That said, you say Aim Stabilizer is lower lag. I wonder what the special sauce is. Do you have a 960fps high speed camera?
BlurBoss
I only have access to 240 FPS camera. Also I said that with 240 Hz + Aim Stabilizer the picture in motion looks definitely clearer than at 240 Hz + DyAc. Not sure about input lag. Overall KD25F fells more responsive.Chief Blur Buster wrote:That said, you say Aim Stabilizer is lower lag. I wonder what the special sauce is. Do you have a 960fps high speed camera?
Unfortunately that's a deal breaker to me. I've decided to return AORUS KD25F, as DyAc + brighter picture provides better gaming experience (better picture) for me than Aim Stabilizer + clearer motion darker picture. Too bad, as AORUS KD25F is just better monitor:Chief Blur Buster wrote:The backlight is overvoltaged during flashes, as LEDs can usually safely flash 3x-4x brighter than steady state.
+Brighter picture when not in Aim Stabilizer.
+More colorful, vivid image - it's more fun to play on this monitor wenh not in Aim Stabilizer.
+Built in crosshairs.
+Better monitor stand - can move keyboard and mouse pad closer to the screen.
+240 Hz with Blur Reduction off produces less blur.
+G-SYNC seem to work - but I'm not sure how relably.
-Overdrive "Speed" produces a lot of ghosting (trails) on the white (or bright) backgrounds
I wonder if there's an adjustment setting for Aim Stabilizer that makes it brighter but a bit blurrier.
There's often a clarity-versus-brightness tradeoff based on the strobe pulse width. The Aim Stabilizer uses a 0.5ms MPRT pulse width, while the XL2546 uses closer to a 1.0ms MPRT pulse width. When used in conjunction with voltage-boosting, this can produce a significant brightness difference too.
The ones on BenQ Zowie is more adjustable, it can get as clear as Aim Stabilizer at darker settings -- using Strobe Utility or the Factory Menu to reduce the strobe pulse width (duty cycle) or Persistence setting. Darker but clearer motion.
BlurBoss
There is no such setting in the standard menu, that's for sure. There is an option that allows to change monitor settings from software called "OSD_Sidekick" it has identical settings as monitor's standard menu. I'm attaching the screenshot.
If I could make this monitor brighter with Aim Stabilizer, I would definitely keep it as the picture quality is so good! Almost as good as AORUS AD27QD with much better response time.
- OSD_Sidekick.png (62.21 KiB) Viewed 23911 times
