Why does Display port and HDMI feel so different?
ayeTop
Post by ayeTop » 10 Jul 2019, 12:18
When playing games on my XL2540 the difference is so huge, but idk which is better input lag wise. I feel better with hdmi but idk if its cause i'm used to it. Also when switching to display port my aim feels a lot faster. Anyone know which is better?
Re: Why does Display port and HDMI feel so different?
Post by Chief Blur Buster » 10 Jul 2019, 12:27
HDMI and DisplayPort can have different latencies. In an ideal world, the latency difference is tiny.
However, I have seen situations where one of the ports have one-frame-less latency because of a different processing pipeline or different chip being used for that port. It's an annoyingly little-tested part of gaming monitors -- the latency differences of different video ports. It can be sub-millisecond but it can be very huge (multiple milliseconds).
Choose the port that feels better for you. When there's a latency difference happening, it is usually DisplayPort has tighter latencies than HDMI -- I'm assuming you're pushing both ports to their full 240Hz.
A Solid lad
Post by A Solid lad » 07 Sep 2019, 02:45
I thought I was the only one... so I didn't mention it.
They also feel different for me.
I also feel like I play better with HDMI, even AMA seems a bit stronger on it.
DP feels smoother, but more sluggish.
Discord | Youtube | Twitch
Takebuchi7
Post by Takebuchi7 » 30 Apr 2021, 20:38
Agreed, on my alienware hw2521hfl @240hz HDMI feels smoother, while displayport kind of feels sluggish, maybe i should try a vesa certified cable.
A Solid lad
Post by A Solid lad » 05 May 2021, 15:42
I tried two DP cables on my XL2540, and I also had the aw2518HF.
Same experience on both of them... HDMI felt more snappy.
I have a few guesses why, but no proof.
ManWhoSoldTheWorld
Post by ManWhoSoldTheWorld » 28 Aug 2022, 10:24
I also agree -> On my Samsung Odyssey G7 32" I prefer 144hz HDMI over 240hz DP
A Solid lad
Post by A Solid lad » 29 Aug 2022, 06:47
Still using HDMI, still no clue what's up with all this. :D
SachsenPowl
Post by SachsenPowl » 11 Jun 2023, 15:40
I have also tested this on my LG 27GP950-B. 120Hz HDMI certified > 160Hz DP VESA certified.
I will hit more one tap shots on HDMI, even it has 120Hz (144Hz on some resolutions)
If this should be placebo feeling this is crazy... Feels so much better on HDMI.
Avi
Post by Avi » 12 Jun 2023, 02:04
Chief Blur Buster wrote:
10 Jul 2019, 12:27
Are you talking on the monitor ports or the graphics card ports?
Post by Chief Blur Buster » 14 Jun 2023, 23:50
Avi wrote:
12 Jun 2023, 02:04
10 Jul 2019, 12:27
Both because you switch port type. HDMI vs DisplayPort. That necessitates choosing a different port on both GPU and monitor!
