BenQ UNIVERSAL 144Hz->220Hz OVERCLOCK for 1080p 144 Hz
MarkBurghouwt123
Post by MarkBurghouwt123 » 13 Jul 2020, 14:29
macexx wrote:
20 Aug 2019, 15:02
Just bought an xl2411p today so ofc the first thing was to try this ;)
Could get it stable at 165hz with ama set to high/premium with DP/DVI-D,
200hz with ama off DP/DVI-D.
With ama high/premium i would get a picture at higher refresh rates but image was distorted same goes for AMA off and 220hz.
how did you do it i really dont understand anything im reading such as timing etc. i tried it with the automatic program, but it still shows out of range with all the same values put in as the original post at 155 hz.
MarkBurghouwt123
Post by MarkBurghouwt123 » 13 Jul 2020, 15:16
Hello guys. I cant get the out of range message away. I have tried with 3 different programs already. the original one always says not responsive. the other 2 just dont work. am i doing something wrong? I have the XL2411P. please someone help
j0rpi
Post by j0rpi » 31 Jul 2020, 11:49
MarkBurghouwt123 wrote:
13 Jul 2020, 15:16
I have a XL2411P aswell, and i'm facing the same issues. Cannot get the "Out of Range" message to disappear, or make it display anything. Tried OORFFixer and OORBuster to no avail. I've only tried DP, as i have no access to a DVI-DL cable.
Post by Chief Blur Buster » 02 Aug 2020, 19:33
One technique that makes this slightly easier is a unique resolution that only has the overclocked Hz -- for example 1920x1079 at the overclocked Hz.
By doing that, it forces a game to reduce the number of mode switches (and thus the number of timings resets needed, such as utilities such as https://github.com/hleVqq/OorBuster ...)
       To support Blur Busters:
       • List of G-SYNC Monitors
       • List of FreeSync Monitors
       • List of Ultrawide Monitors
stras
Post by stras » 06 Aug 2020, 15:04
Hello!
XL2411P (2019 afaik) user here, managed to get stable with 212Hz, 213 also very usable, but gets a tiny artifact every few minutes on the bottom half of the screen. I use OorBuster with the settings on the first page and it works well, no frame skipping.
MarkBurghouwt123
Post by MarkBurghouwt123 » 13 Aug 2020, 13:08
stras wrote:
06 Aug 2020, 15:04
Hello!
my best attempt was with AntiOutOfRange. It showed the screen for half a second with alot of artifacts (212hz). Then it went back to out of range
ziocomposite
Post by ziocomposite » 15 Aug 2020, 20:07
striker333 wrote:
06 May 2020, 04:51
hleV wrote:
23 Jul 2019, 18:10
I coded a little app for personal use (fullscreen CSGO at overclocked refresh rate). You can see the code and download the binary here:
https://github.com/hleVqq/AntiOutOfRange
Upon launch, it automatically detects your current OSD language (0xCC) and Color profile (0xDC) monitor settings, and re-applies those settings after X amount of seconds:
Dude thank you very much thats helped me with 2720z instead of using the switch :D
Installed this but it doesn't seem to do anything at least for my 2720z? Have a dual monitor with 3440x1440 as primary and 2720 secondary. Does it need to be installed/unpacked in a specific location and have softmccs running at the same time?
Annotation 2020-08-15 180723.png (5.42 KiB) Viewed 1068 times
hleV
Post by hleV » 16 Aug 2020, 11:55
ziocomposite wrote:
15 Aug 2020, 20:07
How are you using it? AntiOutOfRange applies OOR fix after the amount of seconds you entered. So you have to enter the seconds, change the refresh rate, then wait for the fix to get applied. Alternatively you can use OOR Buster, which does it automatically.
BenQ XL2411Z
ziocomposite
Post by ziocomposite » 16 Aug 2020, 13:12
hleV wrote:
16 Aug 2020, 11:55
So I'm trying to run Modern Warfare in exclusive Fullscreen Mode.
My Process:
Activate SoftMCCS 0xCC & 0xDC -> Apply 8 seconds to AntiOutOfRange -> Start Game. When the game starts it results in the OOR.
Looking at your screen shot your values are 2 / 25 while mine stay 0 for both.
Also tried OOR Buster and see it on the notifications panel but nothing seems to happen as well.
I'm likely doing something wrong but unsure of what lol. Game is of course fine when running in Full Screen Borderless only applying the SoftMCCS when booting the PC initially.
hleV
Post by hleV » 16 Aug 2020, 13:15
ziocomposite wrote:
16 Aug 2020, 13:12
My Process:
I'm likely doing something wrong but unsure of what.
You don't need SoftMCCS if you're using AntiOutOfRange. Test it by entering 8 seconds, changing refresh rate (don't open the game, just change the refresh rate for desktop) and see if after those 8 seconds anything happens.
BenQ XL2411Z
