Frametime spikes at high fps - 1080p 60hz monitor
Posted: 30 Jul 2019, 15:35
MOBO Gigabyte B450 Aorus Elite
GPU Zotac Geforce RTX 2070 AMP EXTREME EDITION 8GB
CPU AMD Ryzen 5 2600
RAM Team Group Vulcan T-Force 16GB 3000MHz
PSU Kolink 600W 80 Plus Bronze
SSD Samsung 250GB 860 EVO
HDD Seagate BarraCuda 2TB
MONITOR AOC E2460SH (1080p@60hz)
Yes. my PC is overkill to the max for this monitor but i will be upgrading to a 1440p 144hz Monitor (See below).
(Things I've done - windows performance mode on, all gaming bloatware on windows disabled, clear standby memory every 5 minutes, NVIDIA Performance power management mode, no overclocks)
So basically i configured and bought a brand new £1k custom-built gaming PC which is AMAZING (compared to my 10 year old PC).However, it has given me problems when gaming only... everything else seems to be smooth and work perfectly fine. Basically games stutter on my PC at high fps which includes but is not limited to: Shadow of the Tomb Raider (both DX11/DX12), Battlefield 1 (both DX11/DX12), Metro Exodus (both DX11/DX12), CSGO, Dying light and Call of duty Modern Warfare. Somehow GTA V and Call of Duty: Modern Warfare 3 do not stutter at all, it is "buttery" smooth. Now I know that the cause of my frametime spikes are fps drops (when frames drop e.g. -20/30/50fps frametime spike occurs). One common solution is to cap the fps using an in-game frame rate limiter or RTSS. However, doing so does not help... fps drops still occur even at low caps (e.g. 90fps). VSYNC seems to remove all stutters however as my monitor has a refresh rate of 60hz this really isn't a solution with the massive 16.67ms input lag... now this leads to my question. Will upgrading to a Gsync (1440p) 144Hz monitor solve my frametime spike issues (caused by fps drops) or just make them more clear to the eye. Since using vsync at 60hz solved my issues... surely vsync at 144Hz will too, given i can keep that framerate up or enable gsync? Either way I'm looking to upgrade to the Dell S2716DG (1440p 144Hz) soon unless another monitor pops up for a great price.
I'd really appreciate if anyone can help me on this issue or has had similar experience in the past
