Got a acer GN246HL I want lightboost on it but in the nvidia
Control panel all stereoscopic options disapeared I know they were there before so I kno they can be there I got a gtx 1070
Help cant finalize the part with the 3d vision wizard
If the monitor is already showing the option for 3d vision/NVidia 3d then it's already on. (press middle button twice on the monitor to check). Once it's enabled you can usually just set lightboost thru the monitor, uninstall nvidia3d and not use it.
