Page 1 of 2
G sync and v sync in nvidia control panel cause flickers
Posted: 14 Aug 2019, 08:13
by Kranzes
Ok so i have a 240hz g sync monitor (PG258Q) when ever i enable g sync and vsync in control panel and cap my fps 3 fps below my refresh rate (237) i get ton of black screen flickers
i used DDU DIDNT WORK
i tried using an older gpu driver DIDNT WORK
if i disable g sync it fixes the problem...
i dont know what to do...
Re: G sync and v sync in nvidia control panel cause flickers
Posted: 15 Aug 2019, 10:40
by knypol
Got this monitor for more than 1 yr and never got such problems. I always try to be on latest driver&win 10 version. Tested many games limited below 240 fps ingame or with RTSS with nvidia VSYNC ON. I noticed that with Nvidia VSYNC and GSYNC everything is much more fluid than without VSYNC.
Worth to mention is that i use only 1 monitor setup (no other monitor connected to my gfx card).
Posted: 15 Aug 2019, 14:27
by Kranzes
knypol wrote:Got this monitor for more than 1 yr and never got such problems. I always try to be on latest driver&win 10 version. Tested many games limited below 240 fps ingame or with RTSS with nvidia VSYNC ON. I noticed that with Nvidia VSYNC and GSYNC everything is much more fluid than without VSYNC.
i tried with only one monitor connected and it still didnt work you think i should go to the store and tell them about it and they can maybe give me a new one?
i also tried using a different cable
Posted: 15 Aug 2019, 15:45
by knypol
If u can try it on different computer and then go to shop. There should be no black flickering at all.
Posted: 15 Aug 2019, 16:42
by Kranzes
knypol wrote:If u can try it on different computer and then go to shop. There should be no black flickering at all.
its really inconsistent when i alt tab back into the game for 1s its fine then it will flash once and go back to normal and its fine
its like only when alt tabing in
Posted: 15 Aug 2019, 16:57
by knypol
Fast google'ing indeed showing that ppl have kind of flickering problems not only with this particular monitor. One says that is driver problem - if U have time reinstall windows and install latest drivers. Other says its DP cable problem. Bf1, Bf5, Apex, R6S, ROE have no problems on 240Hz in fullscreen mode.
Posted: 15 Aug 2019, 18:25
by Kranzes
knypol wrote:Fast google'ing indeed showing that ppl have kind of flickering problems not only with this particular monitor. One says that is driver problem - if U have time reinstall windows and install latest drivers. Other says its DP cable problem. Bf1, Bf5, Apex, R6S, ROE have no problems on 240Hz in fullscreen mode.
idk the game im playing if Fortnite... i tried a different display port cable...i tried DDU... i tried with only one monitor...i tried older drivers...
Posted: 16 Aug 2019, 03:26
by knypol
Fortnite works good aswell so i suggest test Your monitor on different PC and if this wont help go to shop and replace it.
Posted: 16 Aug 2019, 03:55
by Kranzes
knypol wrote:Fortnite works good aswell so i suggest test Your monitor on different PC and if this wont help go to shop and replace it.
you think it matters that i dont get 240fps on my other pc ? i only get like 160
Posted: 16 Aug 2019, 04:16
by knypol
Try it on CS:GO its free to play now and im sure u'll get 300+ (and limit to 237)
