LG 24GL600F overclock success but message 'out of range'
overclocker12343
Post by overclocker12343 » 18 Aug 2019, 12:18
I overclocked the LG UltraGear 24GL600F 144hz gaming monitor to 244HZ with CRU and everything seems to be working fine, gaming, etc, but the annoying thing is that I get a "out of range" message taking up the middle of the screen. Can anyone help pls?
Boomchakadah
Re: LG 24GL600F overclock success but message 'out of range'
Post by Boomchakadah » 31 Dec 2019, 14:37
I don't know if this works, but it's worth a try. viewtopic.php?f=8&t=5544
VG258QM 280Hz TN (main)| XG2431 240Hz IPS | XL2540K 240Hz TN | XV252Q 1080p 280Hz IPS | XL2546K 1080p 240hz TN | AW2518HF 1080p 240Hz TN | XV240YP 1080p 165Hz IPS | XG2402 1080p 144hz TN | 27GL83A 1440p 144Hz IPS | XL2411P 144Hz TN | XF240H 144Hz TN
mechag
Post by mechag » 23 Mar 2020, 04:26
Hi,
Did you find a solution to this issue?
Thanks.
Post by Chief Blur Buster » 28 Mar 2020, 17:23
Out of Range popups are really annoying, especially if it's a working overclocks.
Various hacks were found with BenQ ZOWIE monitors to dismiss this pop, but "Out of Range" dismiss hacks are very vendor-dependant.
Attempting to dismiss this can be very tricky, but could be a variety of repeat-mode-changes, to DDC commands, to external button pads, and other user-accessible tricks to dismiss the OOR popups that are built into monitors. Sometimes overclock headroom is small (+5 Hz) while it can be huge in others (+100 Hz) -- it depends on the weak links.
mechag
Post by mechag » 29 Mar 2020, 10:03
Funny thing is, I have this same monitor and I cannot go above around 170 before it just goes black. Is it possible that I have a later revision?
Also, at around 165hz overclock I start to see microstuttering and the screen sometimes goes black momentarily if brightness is very high or I am displaying a fast graphic. After I realised that, I switched right back to 144hz and honestly I did not see the difference.
Can I ask how much of a difference is there between motion blur reduced 144hz vs 'stock' 240hz?
Thanks in advance.
Post by Chief Blur Buster » 30 Mar 2020, 14:28
mechag wrote:
29 Mar 2020, 10:03
Assuming GtG=0 (instant GtG) -- then 240Hz will be (240/144) clearer = 1.66x clearer motion.
Mathematically, Blur Busters Law dictates 1ms of persistence translates to 1 pixel of motion blur per 1000 pixels/second.
Persistence is equal to refreshtime for sample-and-hold displays:
But GtG is not zero, so it will diminish the difference between 240Hz and 144Hz. If you get a 240Hz 1440p monitor, it is recommended to make sure you have 0.5ms GtG or 1ms GtG. GtG will bottleneck your motion blur improvements on a smaple-and-hold display.
So in the refresh rate race, it is important that GtG remains much faster than refreshtime. 1ms GtG was unimportant at 60Hz, but 1ms GtG is a gigantic brick wall at 480 Hertz refresh (2ms refreshtimes).
Post by Chief Blur Buster » 30 Mar 2020, 14:31
mechag wrote:
29 Mar 2020, 10:03
This is normal.
(A) You need to double Hz to halve motion blur. (without help by blur reduction modes)
144Hz vs 165Hz is almost worthless. You want 144Hz vs 240Hz, or even 144Hz vs 360Hz.
(B) In certain cases overclocking sometimes worsen GtG due to LCD refreshing behavior
See "LCD Pixels as GtG soccer balls" metaphor.
60Hz vs 144Hz = 2.4x improvement
144Hz vs 240Hz = 1.5x improvement
144Hz vs 360Hz = 2.5x improvement
144Hz vs 165Hz = only 1.1x improvement (this tiny overclock margin is sometimes cancelled out by GtG worsening)
Honestly, I am not surprised you did not see a difference. It's too subtle a refresh rate difference.
It's easier for me to tell apart 240Hz and 480Hz (my experimental unit) than 144Hz vs 165Hz.
mechag
Post by mechag » 30 Mar 2020, 16:52
Thank you for your thorough responses.
morningstarrr
Post by morningstarrr » 08 Dec 2023, 22:42
i overclocked my 240hz monitor 2 430hz did u find a fix
soloine
Post by soloine » 24 Dec 2024, 06:49
I do not know if this advice applies or if it will work. I don't know if your monitor has a separate scaler chip (to the mcu), but if it does maybe you can send it the i2c command to:
  • hide the window (i presume it will be reasserting the message so these first two probably won't work)
  • move the window out of the viewable area (if excessive is acceptable and firmware is not moving the window about)
  • (or maybe just disconnect i2c before the message presents, it won't powersave if kept disconnected)
just been inspired because I got a head unit with a TW8816 and was reading the datasheet that was leaked online (else I would have to snoop on the commands) to make it a monitor.
the TW has a built in mcu which requires a separate memory ic, if that is the layout in your case the i2c should still be externally routed
