ASUS VE278(H) : 60Hz -> 74Hz
Posted: 23 Aug 2019, 12:58
Edit : Removed iPad Air links. They're bad actually. Added NVidia specs.
DISCLAIMER : Overclocking your monitor's refresh rates and other settings might void warranty and/or reduce lifespan ! Attempt this at your own risk.
Refresh Rate : 74Hz
Resolution : 1920x1080 Full HD
Front Porch : 88, 4
Sync Width : 44, 5
Total Pixels : 2200*, 1125*
Polarity : +, +
*Total pixel settings required may vary depending on GPU & cable used.
VE278 displays the OUT OF RANGE error message at or beyond 75Hz.
NVidia restores the original RR automatically.
Default 60hz Test
Galaxy J5 2016 (ISO 100)
https://imgur.com/a/d5VSSeC
Overclocked 74hz Test
https://imgur.com/a/ZHQJqvc
Frame Skipping Test : Negative.
Refresh Rate : 74Hz
Front Porch : 88, 4
Sync Width : 44, 5
Polarity : +, +
Default 60hz Test
