Purchase advice: 240hz screen for rhythm games
Posted: 27 Aug 2019, 19:44
Hello guys! Need purchase advice for 240hz screen with lowest possiable input lag, tearing and highest smooth.
I need such a screen mostly for playing rhythm games like osu and dynamic shooters like quake (example of gameplay+refresh rate effect in osu https://youtu.be/iqWPpP8m0Ag) High refresh rate and low delay allows to perform waaay better in games like osu, because this game require a lot of reaction and feeling of the timing to achive accuracy and speed.
Things that i need:
- 27 inch screen perfered
- gsync for a couple of games (osu can run 1000fps on any toaster)
- High refresh rate and lowest possiable delay + input lag, highest response time (and other "important" parameters on a best level, that would allow me to achive smooth gameplay and fastest reaction)
- Borderless design
- High brightness, nice angles, antiglare screen (like benq that i currently have)
Things that i dont care about mostly:
- fancy rgb (i would perfer to buy custom ambilight)
- fancy "gaming" design
- software gaming features that would not make any sense in osu (like 3D)
- fancy image quality (performance is the priority)
- additional ports, headphone holders, speakers etc.
Options that i can order in my country:
1. ASUS ROG Strix XG258Q, XG248Q , PG258Q + a bunch of other Asus screens (a lot of people call this fastest screen ever, but its 24 inch and cost 500-600$, also i dont rly like this screaming gaming design and red backlight, is this worth to pay 500$ for this in my case?)
2. BenQ Zowie XL2740 + couple of other 240hz benq (currently i own old Benq, its good, but new cost 550-600$ + i dont rly like the design because i plan to buy and put another screen near my main, those plastic parts on left and right of the screen looks weird, i think it does not suite for dual screen setup because of the plastic parts, this screen has a lot of software gaming features, but is this worth to overpay for them?)
3. Acer Predator XB272bmiprz + couple of other Acers ( PRICE is 800$ this is the most expensive 27 inch 240hz screen, design is ok but also gaming, its borderless but also is this worth to overpay for this?)
4. Acer KG271BBmiipx (384$ the lowest price, 27 inch, borderless design, nothing to say but i am not sure if this would have the ultimate performance+delay for rhythm games)
5. LG 27GK750F-B (400-430$ which i see as a sweet spot, design is not "screaming gaming", thin borders, also i tested this and it was quite ok)
My question is: is this worth to overpay 100-200$ for those "gaming" asus, acer, benq, msi, alianware, hp screens with my requirements?
Right now i mostly aim to LG 27GK750F-B because the design is OK, price is also OK, LG is well known for the quality (a lot of internet gaming cafes in my city use lg 240hz)
I dont need any "build in crosshair" or 3d, i just need screen that performs best and would be fastest on the market in simple 2d games.
Also, what is the earliest version of display port, that version supports 240hz output? I need cheap graphics card for a couple of month before i would buy a new good one, can you please recomend me the cheapest graphics card (i would buy used probably) that have a displayport that would support 240hz@1080 output signal.
I hope that i can get help from this nice forum, thanks for the feedback in advance!
Things that i need:
- Borderless design
