Frame Skipping Test - Overclocking - 80Hz
Nokia17Rocks
Post by Nokia17Rocks » 03 Sep 2019, 21:53
Hi everyone! i have made a small adjustment (Overclock) to my HP Compaq S1922 18.5" monitor (1366x768) from 60Hz to 80Hz and used https://www.testufo.com/frameskipping for the test, the pictures are taken with my S7 Edge at the settings the page says (1/10th)
So what do you think about it?
Regards.
Re: Frame Skipping Test - Overclocking - 80Hz
Post by Chief Blur Buster » 03 Sep 2019, 23:04
[Moved to Overclocking topic area]
Yes, you executed the frameskipping test correctly.
And yes, this looks like an overclocking success!
So you're all good :)
Nokia17Rocks
Post by Nokia17Rocks » 05 Sep 2019, 13:04
Chief Blur Buster wrote:[Moved to Overclocking topic area]
Thanks! Alright,
Cheers.
