Acer Nitro XF252Q turns off VRB automatically after standby
timche
Post by timche » 15 Sep 2019, 10:28
I've set VRB to extreme and every time I turn off my PC and the monitor goes into standby, the next day I turn on my PC and the monitor wakes up, VRB is set to off. Anyone else with this issue?
karavanasam
Re: Acer Nitro XF252Q turns off VRB automatically after stan
Post by karavanasam » 15 Sep 2019, 15:52
If VRB is backlight strobing,then it is normal.Nothing is wrong.My monitor(ASUS) also resets my backlight strobing setting everytime it is turned off.It is probably default setting or something for your monitor too.No panic. :D
masneb
Post by masneb » 16 Sep 2019, 12:33
Sounds like a bug, check out my thread for issues on frame skipping and low latency mode.
