x25 / x25f / xl2546
All Unidentified Forum Objects go in this area! Any fun alien talk goes in this U.F.O. Abduction Lounge, even topics other than monitors or computers. Introduce yourself!
OwBoNo
Re: x25 / x25f / xl2546
Post by OwBoNo » 23 Sep 2019, 22:51
1000WATT wrote:
OwBoNo wrote: And do you know if enabling/disabling G-Sync has any effect on the overdrive/colors?
As far as I know is that, monitors with a G-Sync module are further optimized in overdrive and in colors.
I’m not sure if its the G-Sync module that does the tweaking or if its the monitor itself that is already tweaked.
First of all, the presence of a g-sync module when activating vrr uses a dynamic overdrive, unlike monitors without a g-sync module. I will not be able to answer all these questions correctly. I have only assumptions. I think you should ask these questions to Chief Blur Buster.
Hope he sees this message, otherwise will start a new Topic about it.
Thanks again for helping me with this.
Post by RealNC » 24 Sep 2019, 11:39
OwBoNo wrote:And do you know if enabling/disabling G-Sync has any effect on the overdrive/colors?
The G-Sync module was a replacement for the whole PCB of the display initially. Not sure if that changed at some point. But I'm pretty sure that even if the gsync module only replaces parts of the PCB nowadays and doesn't completely take over everything, it is still fully responsible for overdrive, regardless of whether gsync is currently active or not. Obviously when gsync is currently active, the overdrive algorithm is changed in order to handle variable refresh. If gsync is not active, the optimal overdrive algorithm is used for fixed refresh. If gsync is active, the optimal overdrive is used for variable refresh.
(As a side note, I can't believe how it is possible that there's no footage of a modern gsync display being opened up and examined. One would expect that with the amount of youtubers and hardware sites out there somebody would have done it, like they do with virtually every other hardware. But nope, there seems to be nothing. Nobody is curious? Really? They throw a $1000 phone in a blender but non-destructively looking at the innards of a gsync display is a taboo?)
1000WATT
Post by 1000WATT » 24 Sep 2019, 12:50
My guess was: all g-sync monitors are nvidia monitors on which they were allowed to glue the vendor label. Like the founders edition video cards, with asus msi stickers, etc.
RealNC wrote: (As a side note, I can't believe how it is possible that there's no footage of a modern gsync display being opened up and examined. One would expect that with the amount of youtubers and hardware sites out there somebody would have done it, like they do with virtually every other hardware. But nope, there seems to be nothing. Nobody is curious? Really? They throw a $1000 phone in a blender but non-destructively looking at the innards of a gsync display is a taboo?)
2014 G-Sync Upgrade Kit. complete replacement of electronics. https://youtu.be/FMKpJr0KTC8?t=536
2016 pg279q It seems the power board and usb are separate. https://youtu.be/9uafleqeJPU?t=71
1000WATT
Post by 1000WATT » 12 Feb 2020, 12:19
Chief Blur Buster wrote:
09 Aug 2019, 16:20
Yes, the contrast ratio range reduction can reduce the ghosting part. Ignoring the focus differences, and focussing on the coronas/trailing artifact, that is an expected behavior. That depends on how the monitor processes contrast (digitally decreasing white level, increasing black level, to provide overdrive headroom below black, and overdrive headroom above white. Doing this produces fewer coronas and reduced strobe crosstalk).
It is a sort of a pick-your-poison: Do you prefer contrasty colors, or do you prefer eliminating coronas? (But at least that's a user choice)
For those who want to experiment, spend their time and sacrifice contrast.
I propose a method that I used before buying a high-speed camera.
Those who do not want to lose contrast, are looking for perfect settings, asks the question: "which is better? What is worse? What do you recommend?" - Just close this topic, do not waste your time.
Another 240Hz xn253qx monitor fell into my hands. Stock settings r50 g50 b50, contrast 50, overdrive normal. the range of colors is 0-100, the range of contrast is 0-100.
On the stock settings in the test https://www.testufo.com/ghosting#backgr ... &pursuit=1 I see ghosts that do not suit me.
For the method that I suggest, we need a test https://www.testufo.com/chase#backgroun ... &height=-1 .
I adjust each color separately. In the monitor settings, I set r0 g0 b50. I change the viewing angle as shown in the video until the image is shaded. https://youtu.be/e3ofKI2-HTs
Slowly lowering b50 and continuously watching how the ghost changes. At a value of b43, the ghost is very similar to a firework, it seems that the pixels sparkle, at a value of b42, the firework disappears.
I will call it a ghost firework.
The same goes for red and green. I get r35 g38 b42.
In my version of the monitor (r35 g38 b42) contrast 50). For values ​​(r50 g50 b50) not higher than contrast 35. If the method is clear, you can easily translate the rgb values ​​that are pleasing to your eye while maintaining the highest possible contrast.
You decide when to stop!
Recording in one take, but fast).
Stock monitor settings, only the contrast of 50-25 changes.
Speed ​​is 3840.
https://www.youtube.com/watch?v=5B0ExtAJd-I
jpg https://drive.google.com/drive/folders/ ... _UzbVAWIgV
1000WATT
Post by 1000WATT » 31 May 2020, 19:00
I slightly modified the test.
fast
https://1kwatt.github.io/fast/
slow scale
https://1kwatt.github.io/scale/
This is what my xn253qx looks like (slow scale). With stock settings.
Why I want to connect this particular problem with problems from other topics on the forum.
For example, for green.
at a frequency of 240, artifacts are visible on green color 225, 226.
at a frequency of 200, artifacts are visible on green color 232, 233, 234, 235, 236, 237.
at a frequency of 144, artifacts are visible on green color 240, 241.
at a frequency of 120, artifacts are visible on green color 246, 247,248.
When reducing the hz of the monitor or when using vrr with low fps. Artifacts move closer to r255g255b255.
And they become more noticeable at the peak transition colors in games.
For me, the picture on the stock settings at 144hz is just awful. :(
This is not a first generation panel.
Perhaps once again I was not lucky, a lottery with a panel.
And maybe my test has nothing to do with those problems.
