Asus Rog XG258Q flickering issue
b-ry
Post by b-ry » 29 Oct 2019, 00:09
So I have this weird issue with my monitor, can't seem to find anything on it?
Anybody have any idea as to what it is or what is causing it?
What it looks like: https://gfycat.com/quarrelsomedescriptiveblackbird
Any help appreciated, thanks heaps :)
Re: Asus Rog XG258Q flickering issue
Post by RealNC » 07 Nov 2019, 08:46
Could be the monitor, the GPU, the cable, the drivers... Best way to tell is to use the monitor on a different PC and see if it does the same. If not possible, at least try a different cable.
Paft
Post by Paft » 08 Nov 2019, 17:08
I have the same issue. But it only happens occasionally. When it happens it doesn't show up on any other monitor, so it's the display I highly assume. Can't be bothered linking it another machine and waiting days for it to happen. Not quite sure what triggers it either.
Here's my issue:
https://www.reddit.com/r/techsupport/co ... y_flicker/
Here's another persons example:
https://www.youtube.com/watch?v=1rh6F9ueiCs
