Hello guys ,
im playing CS:GO and im facing an issue called input lag and delay ,
that means that the game is not smooth as normal and not working as it used to work .
i need to mention that the game used to work perfect but every week the problem comes back and im out of advices .
im using AlienWare AW2518H 244Hz Monitor , i7-9700k Cpu and 2080ti waterforce GPU .
i read about Gsync a little bit and understand that it rather be OFF so i did ,
and it used to work and after one week the issue came back.
so i did another research and saw the Gsync causes input and delay lag sometimes .
I've tried literally everything! i really need your help in this one , i cant solve this issue.
i really dont understand why i need to expirience those issues after spending my best money on this amazing PC.
maybe some nvidia settings need to be fixed or set it as it needs to fit my pc,
Some dude said that i need to try to play with Vsync and Gsync on together and limit my FPS to 236 since my Hz is 244 , but it make no sense cuz the game worked fine with 300 and over 400 fps before .
I really appriciate those who will read this and try to help me , it has been 4 weeks without playing since that issue .
Thank you so much !
ALIENWARE AW2518H Plz help
- RealNC
Re: ALIENWARE AW2518H Plz help
