xl2546 stuttering
ExzoR4IK
xl2546 stuttering
Post by ExzoR4IK » 01 Dec 2019, 06:13
xl2546 stuttering need help, im playing cs go and my motion not clear, i had 144hz monitor before my xl2546 and motion was way better then on 144hz then on 240, im not using DyAc. please help me Chief if there is any settings do i need to change in factory menu or somewhere else
Q83Ia7ta
Re: xl2546 stuttering
Post by Q83Ia7ta » 01 Dec 2019, 16:45
It's just your PC. Deal with it.
ExzoR4IK
Post by ExzoR4IK » 01 Dec 2019, 17:25
Q83Ia7ta wrote: ↑
01 Dec 2019, 16:45
My PC?You dont know my specs how you can say it is my pc? my specs are z390e asus rog strix mobo. i7 9700k ,rtx 2070 msi ,16gb memory and nvme 1tb
Q83Ia7ta
Post by Q83Ia7ta » 02 Dec 2019, 17:56
Because monitor can't cause stuttering. Seems like your PC can't handle stable stutterless CSGO. Tweak some settings, limit fps for example.
Post by RealNC » 03 Dec 2019, 09:25
Do a frame skipping test:
https://www.testufo.com/frameskipping
Read the instructions highlighted in red. Post the photo.
Also, make sure CS:GO is actually running in 240Hz mode. Check the OSD of your monitor and verify it says "240Hz." If not, maybe you have an old "-freq" CS:GO launch option that makes the game run at lower Hz.
Falkentyne
Post by Falkentyne » 04 Dec 2019, 18:23
ExzoR4IK wrote: ↑
01 Dec 2019, 06:13
Set your XL2546 to 144hz and see if it's smooth. If 144hz is not present, create it in ToastyX CRU yourself, or use the 120hz setting.
If it's glass smooth, but it's stuttering at 240hz, it means you CPU/Videocard is not fast enough to handle 240hz/240 FPS.
