Does my monitor not support FreeSync?
LagBuster
Post by LagBuster » 07 Dec 2019, 09:18
So I tried to enable FreeSync on my monitor... Not sure if I'm missing something obvious, but FreeSync ain't on. :roll:
In terms of what panel it is, the RTD2795 controller menu says it's AUO M270QAN01. Didn't find anything about VRR in the spec sheet for that panel, though.
LagBuster
Re: Does my monitor not support FreeSync?
Post by LagBuster » 07 Dec 2019, 10:27
Ok, I get it now... AMD's FreeSync FAQ says GPU support is from HD 7000 series 2012, but in reality it's from 2nd gen GCN, which started with the HD 7790 2013... No idea why the FAQ doesn't just say that. :evil:
Anyway, don't really mind because I have a new GPU coming in a few days.
Post by Chief Blur Buster » 07 Dec 2019, 13:51
LagBuster wrote: ↑
07 Dec 2019, 10:27
It's a subtlety that also affects NVIDIA native G-SYNC -- further back you even have ambiguities. Sometimes what is supported isn't, because of other complicating factors such as NVIDIA Optimus (co-operation with Intel GPU). Regardless of vendor, once you're at least one to two generations ahead of the minimum, the "Unsupported" problems are much less.
LagBuster
Post by LagBuster » 07 Dec 2019, 14:31
07 Dec 2019, 13:51
Yep. That's partly why I bought the 1660 Super, to avoid any sort of compatibility issues and lack of features. It was definitely high time for an upgrade... ;)
LagBuster
Post by LagBuster » 12 Dec 2019, 06:35
Welp, I installed the 1660 Super + driver and enabled FreeSync on my monitor but I still don't see anything about G-Sync or FreeSync in the control panel. :lol: I do wonder why.
Nector
Post by Nector » 14 Dec 2019, 15:19
Could be free sync on nvidia inly works over display port.
Post by jorimt » 14 Dec 2019, 15:27
https://nvidia.custhelp.com/app/answers ... UyMQ%3D%3D
Do G-SYNC Compatible displays work on both DisplayPort and HDMI with GeForce GPUs?
G-sync Compatible displays will only support variable refresh rate over DisplayPort when connected to GeForce Pascal or Turing GPUs.
Displays: ASUS PG27AQN, LG 48C4 OS: Windows 11 Pro Case: Fractal Design Torrent PSU: Seasonic PRIME TX-1000 MB: ASUS Z790 Hero CPU: Intel i9-13900k w/Noctua NH-U12A GPU: GIGABYTE RTX 4090 GAMING OC RAM: 32GB G.SKILL Trident Z5 DDR5 6400MHz CL32 SSDs: 2TB WD_BLACK SN850 (OS), 4TB WD_BLACK SN850X (Games) Keyboard: Wooting 60HE v2 Mouse: Logitech G Pro X2 SUPERSTRIKE Sound: Creative Sound Blaster Katana V2 VR: Beyond 2, Quest 3, Reverb G2, Index Consoles: N64, Analogue 3D, Dreamcast, PS2, PS3, PS5 Pro, Switch 2, Wii, Xbox, Xbox 360, Analogue Pocket + Dock Scaler: RetroTINK 4k
LagBuster
Post by LagBuster » 14 Dec 2019, 18:43
I am using DP. But I think the people who sell this monitor lied about it doing VRR. :roll: I think they included that option in the control panel but it doesn't actually do anything.
I bought it because it was cheap... :roll: Not too worried about it, though. So it's fine.
Tancred
Post by Tancred » 23 Jan 2020, 14:52
Are you running Win7 or 10?
I'm not sure, but I think running a FreeSync "G-Sync Compatible" monitor with an NVidia GPU requires Win10.
(I myself am trying to get VRR running on an 1660 Ti with an LG 27GL850 and failing at it, maybe because of Win7)
LagBuster
Post by LagBuster » 23 Jan 2020, 15:48
Tancred wrote: ↑
23 Jan 2020, 14:52
Win 7, so maybe you're right. :shock:
