Low latency mode conclusion?
charbel1011
Post by charbel1011 » 10 Dec 2019, 15:26
I have a 2080 ti,32 gb ram, i9 9900k. pretty powerful system. i play with g sync on and riva tuner capping my fps under my monitor hz by -3 so 117. because my monitor is 120hz. should i set low latency mode on,off,ultra?
Re: Low latency mode conclusion?
Post by jorimt » 10 Dec 2019, 16:14
See my recently updated Optimal G-SYNC settings here:
https://www.blurbusters.com/gsync/gsync ... ttings/14/
As well as these posts in this ongoing thread about the setting when used with G-SYNC, here:
viewtopic.php?f=5&t=5903&start=30#p44825
viewtopic.php?f=5&t=5903&start=110#p45250
Summary:
NULL (G-SYNC + V-SYNC + LLM Ultra) auto-caps the FPS, and in best cases, has similar input lag levels to RTSS. Downside is that you can't manually select the FPS limit, and it does not work in games that don't support the external manipulation of the pre-rendered frames queue or games running DX12 or Vulkan, currently.
charbel1011
Post by charbel1011 » 10 Dec 2019, 16:28
jorimt wrote:
10 Dec 2019, 16:14
Summary:
so g sync and v sync on LLM to ultra? is the best right now? and what do you mean by auto caps for the fps i cannot cap it with riva tuner?
Post by jorimt » 10 Dec 2019, 17:25
When used with G-SYNC + V-SYNC, they both cap the FPS. So pick one; RTSS or NULL. NULL auto-caps to ~117 FPS at 120Hz I believe. If you want to use RTSS to limit FPS, use LLM "On" instead.
All other details (and then some) are available to you in the links of my previous post.
