Max Frame Rate: Cap Frame Rates, Save Power, and More
You asked for it - the number one community requested feature is here!
Now, you can set the max frame rate for a 3D application or game. This feature is particularly helpful when trying to save power, reduce system latency, or keep within a specific Variable Refresh Rate range on a G-SYNC or G-SYNC Compatible display.
Saving Power: Enable Max Frame Rate (NVIDIA Control Panel > 3D Settings > Max Frame Rate) and set your power management mode to “Optimal Power”(NVIDIA Control Panel > 3D Settings > Power Management Mode). While in this mode, GPU frequency is reduced and uses less power. For laptop users, Max Frame Rate also works alongside with Battery Boost and Whisper Mode. If either of these modes are enabled at the same time as Max Frame Rate, the NVIDIA Control Panel will cap the framerate to the lowest of the limits.
Reducing System Latency: Enable Max Frame Rate and set your power management mode to “Prefer maximum performance” to reduce latency. While in this mode, the GPU is kept at higher frequencies to process frames as quickly as possible. To maximize latency reduction in GPU bound scenarios where FPS is consistent, set Max Frame Rate to a framerate slightly below the average FPS and turn Low Latency Mode to Ultra.
Staying in VRR Range: Set the Max Frame Rate slightly below the maximum refresh rate of your display to stay within the Variable Refresh Rate range - providing a no-tear, low system latency experience! For the smoothest, no tear experience, set the low latency mode to Ultra and turn VSYNC on.
Would be interesting to test this against RTSS input lag difference.
GeForce Game Ready Driver 441.87 with FPS CAP
- RealNC
Re: GeForce Game Ready Driver 441.87 with FPS CAP
