Frame capping question with weaker GPUs
Posted: 27 Jan 2020, 22:29
by djbigbear
Hi,
If I have 180hz G-sync monitor, but my meek 1060 3GB could only perform 60 or 90 minimum FPS in certain games, should I cap those game performance to 60 FPS and 90 FPS each or should I just leave it at 177 FPS?
Re: Frame capping question with weaker GPUs
Posted: 28 Jan 2020, 06:49
by RealNC
I like to cap my FPS to somewhere near the average FPS of a game. It feels more consistent that way. I don't like my FPS to go from 80 to 150 and then back again all the time. Also, in many cases being capped reduces input lag somewhat as well.
Posted: 28 Jan 2020, 10:06
by djbigbear
Ah! so that's how it is with G-sync.. thank you very much!
Posted: 28 Jan 2020, 12:57
by RealNC
djbigbear wrote: ↑28 Jan 2020, 10:06
Being able to cap my FPS to whatever value I want without getting stutter is actually one of the primary reasons I got a gsync display
Posted: 28 Jan 2020, 18:29
by djbigbear
RealNC wrote: ↑28 Jan 2020, 12:57
I am so impressed by this tech.. it kinda went sideways from what I knew about conventional GPU performance.
But hours ago I tried installing an old RTS game Red Alert 3 Uprising which has in-game cap of 30 FPS, the G-Sync went ballistic... My mouse cursor. and camera scroll stutters badly, but if I keep the camera still on 1 spot, everything is smooth.
Maybe this is the limitation of G-sync for 30 FPS and below, you could fool the display but you couldn't fool the input rate. I hope there would be a fix for this in the future.
Posted: 01 Feb 2020, 14:54
by ELK
djbigbear wrote: ↑28 Jan 2020, 18:29
Gsync has a minimum fps. If you go below this fps then it starts showing frames twice. If your display has a minimum gsync refresh rate of 40 then you will see 20fps in a 30fps game.
Posted: 02 Feb 2020, 13:31
by RealNC
ELK wrote: ↑01 Feb 2020, 14:54
That's not correct. You will see 30FPS just fine because of LFC (30FPS will result in 60, 90, 120, etc, Hz, depending of what the LFC algorithm thinks is best.)
