Please Help upgrading to V2 on the XL2720z
superslugz27
Post by superslugz27 » 15 Apr 2014, 08:15
Hi,
I just upgraded from V1 to V2 even-though when I upgraded it never said pass, but it did upgrade to the new firmware and the Blur Busters utility works, but now the "low blue light" is dithered out for me. Is this a feature that is gone with V2?
Please help
superslugz27
Re: Please Help upgrading to V2 on the XL2720z
Post by superslugz27 » 15 Apr 2014, 08:34
I installed the display pilot from the cd and low blue light works now.
superslugz27
Post by superslugz27 » 15 Apr 2014, 08:47
Well, I guess I spoke too soon, as soon as I saved the profiles it dithered out the low blue light function.
Falkentyne
Post by Falkentyne » 15 Apr 2014, 09:21
You cant use low blue light with profiles.
It only works with preset modes. It does not work with profiles.
Post by Chief Blur Buster » 15 Apr 2014, 09:29
That's the way it was for both V1 and V2.
Are you sure the behavior changed when you upgraded from V1 to V2?
superslugz27
Post by superslugz27 » 15 Apr 2014, 11:27
No, but now my monitor will not go to 140mhz and the at 120 the monitor keeps shutting off. Do you think i need to reflash the firmware?
superslugz27
Post by superslugz27 » 15 Apr 2014, 11:58
This is what I get when I try to flash it.
Blank OK.
Program Message : Programming ...
Program OK.
Verify Message : Verifying ...
Verify Fail at 0x000003
Verify Error.
End time: 12:55:55 PM
superslugz27
Post by superslugz27 » 15 Apr 2014, 12:09
Monitor power switch just flashing white and will not turn on...
superslugz27
Post by superslugz27 » 15 Apr 2014, 12:14
Reset the power and no flashing white and no red light I think the monitor is dead...
Post by Chief Blur Buster » 17 Apr 2014, 14:47
Let me try to help out here:
There are two people here that got it working by repeating the firmware upgrade process again:
1. Unplug monitor from power for a few seconds.
2. Plug in monitor.
3. Turn off your monitor, keep it in standby mode. Do not connect any cables except VGA cable
4. Follow procedures at http://www.blurbusters.com/benq/diy-fir ... -z-series/
If it fails, try:
- A different VGA cable from the monitor to the MSTAR ISP;
- Plug your MSTAR ISP to a different USB port (not through a hub);
- Upgrade your monitor from a different computer;
Which MSTAR ISP are you using? Are you using the unit obtained from cart100, or one of the other clones?
There are also more people who had similar issues as yours, but they solved it by repeating the upgrade process again:
http://forums.blurbusters.com/viewtopic.php?f=13&t=604
So they have successfully fixed this by repeating the upgrade.
Hundreds have followed the DIY upgrade successfully, so what happened here is rare. Let me know if the suggestions above solves your problem.
