Downsampling with MBR 2420z?
Posted: 16 Apr 2014, 08:00
Can it be done? I think I know the answer to this just wanted to be sure.
Who you gonna call? The Blur Busters! For Everything Better Than 60Hz™
https://forums.blurbusters.com/
The answer would be the same as: http://forums.blurbusters.com/viewtopic.php?f=2&t=619writer21 wrote:Can it be done? I think I know the answer to this just wanted to be sure.
For those reading this, make sure you patch the dotclock with the ToastyX clock patcher -- http://www.monitortests.commasterotaku wrote:At 80Hz or more, the image was displayed correctly when creating that custom resolution, but then it wasn't listed, as if I didn't create it.
It is already patched. It's something I always do after installing new Nvidia driversChief Blur Buster wrote: Try patching the dotclock with the ToastyX clock patcher -- http://www.monitortests.com
