FREESYNC HZ Counter Mismatch based on FPS Limiter?
Hey guys, So I recently got a LG27GL850 coming from a CHG70 and an old XB241H Gsync Module monitor and I'm using a Nvidia RTX 2070.
I've noticed something interesting after testing all three of these monitors.
Gsync seems to be 1:1 HZ to Framerate perfect. There is no mismatch going on and everything is working as intended.
Freesync on the other hand seems to have HZ counter mismatch that bounces around when FPS Cap is applied. For example, it could be 90FPS Capped and it could bounce anywhere from 80,to 88,89,90,91,92, and 100.
When the FPS is Uncapped the HZ counter seems to be much more accurate to whatever my FPS currently is.
Then I noticed that it is only when using In-Engine limiters or CPU level limiters such as RTSS is what causes the HZ mismatch even though in RTSS's case, gives rocksolid frametimes. (Note that this applies to games, for whatever reason, running Nvidia Pendulum or Amd Windmill doesn't cause this issue)
When I use Nvidia Inspector "Limiter V2 - Allow All", which I believe is a Driver level limiter, the frametimes become much more chaotic but the HZ rate is a perfect 1:1. However, this comes at the cost of input latency as it increases pretty dramatically compared to RTSS and In-Engine limiters making it pretty unusable and somewhat defeats the purpose of adaptive sync.
Does anyone know why this might be happening? Why does Rocksolid RTSS frametimes cause such mismatch in HZ counter while a Driver level limiter with chaotic frametimes give perfect HZ counter?
Is the Hz Mismatch an issue? Will I get screen tearing under this situation using an RTSS limiter?
I personally don't notice any screen tearing but I'm probably the worst person to ask to spot it. I've tried to use my phone camera to check but couldn't really figure it out.
I'd appreciate it if someone could help me out, thanks!
StanleyCKC
- jorimt
Re: FREESYNC HZ Counter Mismatch based on FPS Limiter?
Long story short, ignore it; no matter what it says, it's not having an effect on your set FPS limit (or fully reflecting) actual G-SYNC performance.StanleyCKC wrote: ↑07 Mar 2020, 01:52FREESYNC HZ Counter Mismatch based on FPS Limiter?
In most cases on G-SYNC Compatible monitors, the meter was originally created and tuned for native FreeSync operation, which has different driver implementation (AMD VRR) than the software variant of G-SYNC (Nvidia VRR). This difference likely creates more counter misreads than if you were using an AMD GPU w/FreeSync on that same monitor.
Use a system-side FPS counter for a more accurate current FPS/Hz readout instead, and only use that monitor's built-in meter to verify whether G-SYNC is currently engaged, as that is the only thing it can tell you that a system-side readout cannot: static = fixed refresh, fluctuating = variable refresh (where what the fluctuating number is at any given point in this case not mattering as much as whether it is fluctuating).
Displays: ASUS PG27AQN, LG 48C4 OS: Windows 11 Pro Case: Fractal Design Torrent PSU: Seasonic PRIME TX-1000 MB: ASUS Z790 Hero CPU: Intel i9-13900k w/Noctua NH-U12A GPU: GIGABYTE RTX 4090 GAMING OC RAM: 32GB G.SKILL Trident Z5 DDR5 6400MHz CL32 SSDs: 2TB WD_BLACK SN850 (OS), 4TB WD_BLACK SN850X (Games) Keyboard: Wooting 60HE v2 Mouse: Logitech G Pro X2 SUPERSTRIKE Sound: Creative Sound Blaster Katana V2 VR: Beyond 2, Quest 3, Reverb G2, Index Consoles: N64, Analogue 3D, Dreamcast, PS2, PS3, PS5 Pro, Switch 2, Wii, Xbox, Xbox 360, Analogue Pocket + Dock Scaler: RetroTINK 4k
StanleyCKC
Hey Thanks for the reply. So I guess I should just ignore it as long as its fluctuating.jorimt wrote: ↑07 Mar 2020, 09:34Long story short, ignore it; no matter what it says, it's not having an effect on your set FPS limit (or fully reflecting) actual G-SYNC performance.StanleyCKC wrote: ↑07 Mar 2020, 01:52FREESYNC HZ Counter Mismatch based on FPS Limiter?
However, what about in cases where the HZ Counter caps out at 144hz? For Example using RTSS On CS GO, setting it to anything over 128 limit will cause the HZ Counter to cap out at 144hz and the closer to the 144cap the longer the HZ counter stays on 144hz. Setting the RTSS limit to 140 will pretty much lock the HZ counter to 144hz while occasionally dropping down to 135-138hz for a split second. Setting the limit to 138 has a more 50/50 split between when its capped at 144hz and when its fluctuating below that.
So in the case where the HZ Counter caps out at 144hz does that mean adaptive sync is no longer engaged?
If I have V-sync enabled would it then be using V-sync in that case, causing additional input lag?
Or, if my FPS limit is still lower than the 144hz Cap will it simply not engage adaptive sync because the HZ counter capped out at 144hz but also not switch to V-sync which would mean I get tearing?
- jorimt
If both the system-side FPS readouts (Afterburner, etc) AND the monitor Hz counter show a static "144," yes, however, if only the monitor Hz counter shows a static "144," whereas the system-side FPS readout still shows a number below that, no; it's a false reading on the monitor Hz counter's part in these instances.StanleyCKC wrote: ↑07 Mar 2020, 16:59So in the case where the HZ Counter caps out at 144hz does that mean adaptive sync is no longer engaged?
I doubt these built-in monitor refresh rate meters were originally intended to work with G-SYNC Compatible mode on (what were originally only) FreeSync monitors.
Also, just to note, I have a native G-SYNC monitor w/module (XB271HU), and while its built-in Hz counter isn't nearly as sporadic as what I've heard reported (you aren't the first to ask this on these forums) with FreeSync monitors in G-SYNC Compatible mode, even it jumps to "144" (@144Hz) occasionally when the system-side FPS readouts don't. From my experience, the Hz meter is approximated and maybe even possibly prone to changing reporting behavior just from OS and/or GPU driver updates.
So, again, I'd take it with a grain of salt and rely more on the system-side FPS readouts.
StanleyCKC wrote: ↑07 Mar 2020, 16:59However, what about in cases where the HZ Counter caps out at 144hz?
That's normal. Monitors can't tell what frame rate the GPU is running at.
At high frame rates with frame rates beyond refres hrates, it is possible for multiple frames are essentially spliced into the same refresh cycle. Monitors can't tell.
If you have seen high speed videos at www.blurbusters.com/scanout then refresh cycles are delivered onto a monitor's screen in a top-to-bottom manner (the 'scan out'). This is also how it's done over the cable. But during VSYNC OFF, or during LFC operation, you can have a very different number of frames than refresh cycles.
During VSYNC OFF, one refresh cycle may contain multiple frameslices. Monitors can only count refresh cycles, not frames.
The fps counter and the Hz counter only are in better sync ONLY during VSYNC ON mode (non-VRR mode, non-VSYNC OFF mode, not Fast Sync, not Enhanced Sync), and only becomes identical if both sides are using the exact same averaging algorithm.
Any use of any sync technology other than VSYNC ON, will always create divergences between Hz counters (monitor side refresh cycle counting, misnamed as fps counters built into monitors) and fps counters (GPU side frame counting)
Also, sometimes the averaging math is different. Sometimes one side is instantaneous and sometimes one side is averaging. During fluctuating frame rates, the 0.1sec framerate average can be totally different from the 1sec framerate average.
Even if you synchronize fully using VSYNC ON (non-VRR, no Fast Sync, no Enhanced Sync), there is no way to tell if the Hz counter (monitor side) and the fps counter (GPU side) is using the same average algorithm.
equaNJ
Hey chief. Thanks for this reply, and sorry to necro this thread if that's an issue, but I have a question relevant to your reply. Do these refresh rate readings that are seemingly 'all over the place' at times have any negative bearing on input delay? I know that there is inherent delay to be expected with the use of G Sync / Freesync vs 'no sync', but are these sporadic fluctuations in refresh rate readings on the monitor's side cause to believe that thus the input delay is also similarly inconsistent, despite consistent frametimes when using a limiter (in-game or RTSS) that shows stable fps? Ideally I would hope not of course, as I would think consistent input delay is very important when gaming competitively. Thank you!
