Exceeding the max. pixel clock of a monitor harmful?
Posted: 21 Mar 2020, 20:00
Question:
Is raising the pixel clock value in CRU beyond the maximum pixel clock of a monitor harmful? Could it damage the monitor?
At present, I use a Dell P2720D (great monitor, by the way).
CRU tells me about this monitor:
V rate: 49-75 Hz
H rate: 29-113 Hz
Max pixel clock: 280 MHz
By default, this monitor comes with 2560x1440@60Hz.
I created a custom resolution of 2560x1440@74Hz (the difference between 60 Hz and 74 Hz is worth it in games!).
But I could only achieve this refresh rate of 74 Hz by using settings that imply a pixel clock of 291.29 MHz - which is beyond the specified max pixel clock of 280 MHz. - (The H rate is within the permitted range (see above): 110.337 kHz.)
Without getting too technical, does disrespecting the maximum limit of the pixel clock reduce the life-span of a monitor or cause any damage?
All I can say is, that the monitor picture is normal, responsiveness in games is excellent - but I am worried because I did not respect the maximum pixel clock. (I am not that worried when creating lower custom resolutions, of course)
Thanks for useful replies.
V rate: 49-75 Hz
H rate: 29-113 Hz
