Custom resolution 182Hz on Zowie XL2540 (ToastyX)
joddly
Post by joddly » 07 Apr 2020, 09:02
Hello,
I have a XL2540 monitor and i am following the guide https://blurbusters.com/faq/advanced-st ... stalk-faq/
I want to try the 182 hz custom trick. However, i want to do it on a custom resolution at 1798 x 1080 and not 1920 x 1080.
What values should i put in the application from ToastyX?
Should the values be the same as in the screenshot at https://blurbusters.com/faq/advanced-st ... stalk-faq/, except that i just change 1920 to 1798?
Best regards
alexander1986
Re: Custom resolution 182Hz on Zowie XL2540 (ToastyX)
Post by alexander1986 » 08 Apr 2020, 17:44
joddly wrote: ↑
07 Apr 2020, 09:02
Hello,
Best regards
can't help you with the values you need, but i'm curious about how you find the 182 hz trick on 1920x1080? like on the blur busters testufo motion tests, do you find the 182hz trick to give noticeably improved strobe crosstalk and artifacts and so on? if you ever have the chance to record a highres video and/or highres photos of the test at 182hz it would be really cool to see that! at perhaps different AMA/DyAc settings too (or blur reduction in your case with the xl2540 as its not called DyAc on that model I guess)
cheers !
The1Mach1ne
Post by The1Mach1ne » 06 Jun 2020, 08:03
joddly wrote: ↑
07 Apr 2020, 09:02
Hello,
Best regards
I don't think it's that easy but I also would like to know for 1280*720
