New rig build, want to build around FPS
Posted: 04 May 2020, 05:21
So Im looking to build a new rig, my concern is that my main go to games are BR (currently CoD Warzone) and are hard to push high fps.
Even if I go all out (which I may) I can expect framerates of 200-250 fluctuating and certainly not stable 244.
I currently have a XL2720Z v3 OC'd at 220. I've played at 220 on it with Kovaaks etc and it feels amazing hence the new rig/wanting to achieve higher FPS in BR games. The new BenQ with 0.5ms 244 DyAc sounds amazing but will this be worthwhile for BR games where I might only hit 200? Might I be better off 1440p even though I only care for competitive advantage since then I can hit the max refresh and get some additional clarity for distance? (I've never played on 1440p so hard to say).
I understand the general rule for competitive edge is 1080p max frames but I'm wanting some opinions on if this holds for BR games where 244hz is unlikely and there are more long range gunfights?
Thanks for any help!
Db
Db
