Managed to force Display Scaling on XL2411P
MK-
Post by MK- » 08 May 2020, 10:03
If someone need a guide, I will make it. Btw, I launched it on 144 hz, not 120 :o :D
urut
Re: Managed to force Display Scaling on XL2411P
Post by urut » 09 May 2020, 10:25
So how you do that, can you tell? What OS you've got?
MK-
Post by MK- » 10 May 2020, 01:56
urut wrote: ↑
09 May 2020, 10:25
I use Windows 10 1909
First you need to buy hdmi 2.0 cable. Then you download this https://github.com/hleVqq/OorBuster and cru 1.4.You can just paste my EDID https://drive.google.com/file/d/1wiHFYf ... sp=sharing. The only resolution that works with 144 hz display scaling for me was 1280*960 because when I tested it on 1440*1080 I had a black screen. And you cannot use 144hz fullhd on hdmi cable, so when you use your pc on fullhd you simply use display port cable. So, when you want to play, you just plug your hdmi cable.
1000WATT
Post by 1000WATT » 10 May 2020, 03:31
MK- wrote: ↑
08 May 2020, 10:03
viewtopic.php?f=8&t=5544&start=230#p49983
